Page 67 of 144 FirstFirst ... 1757626364656667686970717277117 ... LastLast
Results 991 to 1,005 of 2154
  1. #991
    Aug 2019
    hello please i want immo off for iveco 281011228
  2. #992
    Oct 2018
    Hello everyone,
    i need DTC off P2279-11
  3. #993
    Feb 2018
    help me please dpf off toyota urban cruise edc17cp07
  4. #994
    May 2019
    Red face need some help the
    hello its possible to have IMMO OFF FOR THIS ECU 036 906 034 BH
  5. The Following User Says Thank You to bernuly For This Useful Post:
    Giavarosky (18th November, 2019)
  6. #995
    Dec 2010
    Quote Originally Posted by bernuly View Post
    I don't think that is the correct read of the ECU
  7. #996
    Oct 2016
    barcelona
    Default dtc off p2452
    good morning, could you help me to eliminate dtc p2452 (differential pressure sensor open circuit) of this renault megane 1.9 dci f9qe8 no dpf, the fact is that its ecu burned and was replaced by other software and harware, and although the vehicle did not is dpf, error p2452 comes out. thanks in advance, with mtx remove not let me remove dtc. I wait for your help
  8. #997
    Oct 2015
    Need egr off swirl - flap off vito 2004 EDC16c2
  9. #998
    Sep 2019
    Hi,need map for Peugeot 308 2.0 hdi ,FAP off EGR off more power ,Delphi DCM 3.4.
  10. #999
    May 2011
    Egypt
    Default me7.1 lambada remove
    can you help with me7.1 to remove lambada and catalytic please
  11. #1000
    polska
    Hi, i need dtc p2002 from sorento, ecu ist edc17c08, many thanks
  12. #1001
    May 2009
    Madagascar/Antananarivo
    Default DPF SCR OFF SPRINTER 3.0L W906
    Hello DK members,
    Please, can someone help me for dpf and scr off on sprinter 3.0l w906 ecu edc17cp49
    ORI EDC17CP46 MB 17092019 FAD.rar
  13. #1002
    Nov 2016
    Serbia PK
    Please DTC off P1429
  14. #1003
    Sep 2019
    Is anyone able to remove DTC 19586 please. Audi A2 ATL EDC15, EGR valve and cooler removed, recurring DTC is 19586 - EGR System - P3130 - 35-10 - Regulation Range Exceeded - Intermittent.
    Thank you.
  15. #1004
    Jan 2018
    please can you programm the lambda's off??
    opel astra H 2008 105pk 1.6 petrol original
    thanks!!
  16. #1005
    Sep 2018
    Angola
    Default edc17c54 dtc remove
    I have VW crafter with ecu edc17c54 and i need to remove dtc, the dtc is 4087 p0322 - engine speed sensor.
    Can you help me please?
    The car work fine and i changed the sensors and checked the wires and all are ok, soo i need to remove the dtc because the check engine light.
