If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
I do not answer in private questions that can be solved in public.
jettakompressor (30th May, 2021)
Hi possibe is meake dtc off from opel delco e87 petrol 1.4 nel
p0171 thanks
Hi!
I have blanked the EGR valve with plate and now I need EGR OFF for the ECU.
SEAT TOLEDO 2001 1L6 16v BCB 77kW I need help with DTC OFF in:
Error code P0401 - Exhaust Gas Recirculation Flow Insufficient Detected.
Help me Bmw 335i e92 LAMDA OFF frends ME9.8
mixauto (7th June, 2021)
HI man, need DPF and EGR FOrd Ranfer 3.2 SID208
Needing DPF EGR Adblue and CAT on EDC17CP52 4P10
Thanks in advance![]()
hi
need off dpf end egr from edc17cp02 0281016065 1039532783 Bmw X3, my solution with dpf egr remover cut power end generic fault 4933 air to egr 4BDA fuel presuply 3F25 charge air tube
hy please help with a crafter 2.5 dtc off p0546crafter 2.5.rar
Can you help me with DTC off on Octavia 3 1,4TSI MED 17.5.21?
I need off:
2783 - Internal Control Module Memory
P160A 00 [167] - Check Sum Error
Thank you!
Hello. I need OFF DPF an FLAPS in Mercedes w211, OM642, 320CDI. Dump by Galetto 1260.
Need DTC OFF P0488 EDC17C84 (Exhaust Gas Recirculation Throttle Control Circuit "A" Range/Performance)
Renault Trafic 3 2015 1.6dci EDC17C84 10SW0110081251_8E0
ALREADY RESOLVED!!!
Thanks friends!
if I have helped just press [Thank You] and [REP] buttons.
I am looking for ECM Titanium FULL with the Driver Maker plugin is preferred, but is not required. Even without subscription.
Genuine preowned. Please PM or contact by email if you have for sale.
Hi ,
I need to disable Dpf and Scr on this file Fiat Talento 1.6 Mjet with Bosch Edc17c84 by Renault .
Thanks in advance .
