Page 5 of 24 FirstFirst 1234567891015 ... LastLast
Results 61 to 75 of 347
  1. #61
    Sep 2012
    ecu 95160 immo on.rar That's my Berlingo eeprom file. Thanks in advance
    EDIT:
    Quote Originally Posted by gkogkolos View Post
    woodoo upload your file bro and Ill make it immo off for you without needind to telecode it after or cut any pins etc.
    It will work like a charm as is, just upload it and inform me to check it
    regards
    Big Thanks to gkogkolos! Very helpful guy. Sorted my file in just couple seconds. And it works perfectly! Thanks again
  2. The Following User Says Thank You to woodoo For This Useful Post:
    ernesto1670 (17th July, 2017)
  3. #62
    Spain
    gkogkolos, this is my file.
    Thank you
    If I helped, please, use buttons reputation + thanks.
    The richest is not the one who has the most, but the one who needs the least. (San Agustín)
    Many thanks
  4. #63
    gkogkolos's Avatar
    Oct 2015
    Athens, Greece
    Default J34P IMMO OFF TOTAL
    IMMO OFF TOTAL
    Just write the file and start your engine..
    Press Reputation +1 = Password in PM
    regards
  5. The Following 10 Users Say Thank You to gkogkolos For This Useful Post:
    accordcdz (30th October, 2018), autosuper (22nd June, 2018), cyadder (19th August, 2019), dansil (27th June, 2019), eliet2000 (8th June, 2023), ernesto1670 (17th July, 2017), kaw (30th August, 2019), NORSHAN (2nd November, 2018), shegora (18th November, 2018), zakharprzn (19th September, 2018)
  6. #64
    Spain
    IMMO OFF TOTAL
    regards
    Good job gkogkolos, immo off, worked perfectly.
    Thank you very much.
    Many thanks
  7. The Following User Says Thank You to ernesto1670 For This Useful Post:
  8. #65
    assitutto's Avatar
    May 2009
    Milano, Italy
    hello gkogkolos this is my file, can you help me with immo off? thanks
    Ecu tuning, DPF, EGR and FLAP remove
  9. The Following User Says Thank You to assitutto For This Useful Post:
    ktome (4th July, 2022)
  10. #66
    gkogkolos's Avatar
    Oct 2015
    Athens, Greece
    Default IMMO OFF TOTAL
    Hello bro,
    Start your engine..
    regards
  11. The Following 4 Users Say Thank You to gkogkolos For This Useful Post:
    assitutto (27th July, 2017), kenrique10 (30th January, 2018), ktome (4th July, 2022), stilo115cv (2nd February, 2018)
  12. #67
    ttzag's Avatar
    digital-kaos
    need immo off for this ecu please ?
    thank u in advanced
    Actions speak louder than words
  13. #68
    gkogkolos's Avatar
    Oct 2015
    Athens, Greece
    Quote Originally Posted by ttzag View Post
    thank u in advanced
    IMMO OFF TOTAL
    regards
  14. The Following 7 Users Say Thank You to gkogkolos For This Useful Post:
    ahmed al (5th February, 2018), dudul (15th September, 2017), ktome (4th July, 2022), maybach_ (29th August, 2017), Randex (24th August, 2017), ttzag (2nd August, 2017), zanovo (6th December, 2017)
  15. #69
    Jul 2016
    Quote Originally Posted by nazaeas View Post
    Attachment 402298
    your off ok
    press thanks.
    plese i need pass
  16. #70
    Aug 2016
    Yorkshire
    Hi pal,
    do you have the solution for J34P AAE immo off Berlingo 2008 B8, BSI broken by me
  17. #71
    mixauto's Avatar
    Ukraina Kharkov
    Pass pls ��
  18. #72
    Feb 2016
    I need immo off Peugeot 207. ECU Valeo J34P. Please immo off gkogkolos
  19. #73
    Dec 2010
    To anyone who has problem with J34P & J34P-AAE just upload your file and Ill make you immo off that will no need diagnosis tool after that, no check engine, no dtc errors, no problem with rpm limits no problem with electrofuns
    Just upload your 95160 and inform me via PM
    regards
    Here is one, seems work different than other J34P i met....
  20. The Following 2 Users Say Thank You to MatthewS For This Useful Post:
    jenya (18th October, 2022), ktome (4th July, 2022)
  21. #74
    Garage
    Hi.
    Gkogkolos can you make for me immo off?
    Here os my file.
    THANX
    B.R.
  22. #75
    RUSSIA Kaluga
    Hello friends/
    Please help with immooff for Peugeot Partner 1,4L V8 Valeo J34P-AAE 95160
    Thanks.
