Results 1 to 11 of 11
    iamfooser's Avatar
    Sep 2012
    Default Xprog win 7 64bit driver problem
    Hi guys,
    Recently I am having trouble installing my original xprog driver on a win 7 64bit. Everything was working fine until recently. Tried 2 laptop and both cant be installed.
    It is working fine on my win xp 32bit though.
    I have tried window updates,registry cleaner but nothing seems to work. Hope someone here can help with this. Thank in advancs.
    vanos batam's Avatar
    Batam-Indonesia
    I though dump c46 from xprog..
  3. The Following User Says Thank You to vanos batam For This Useful Post:
    iamfooser (16th October, 2016)
    iamfooser's Avatar
    Sep 2012
    I have tried. Dump file the same bro.
    Could it be ftdi chip? Anyway to check that?
    Sent from my EVA-L19 using Tapatalk
    Jul 2016
    Maybe it's a FTDI clone chip and you need to install the older FTDI-Driver. It's a known problem with FTDI-Clone-Chips (and there are a lot of them). Google for "ftdi chip clone driver" and it maybe helps.
    Gavra's Avatar
    Belgrade/Melbourne
    Just disable digital driver sign request in windows and u r good to go..all X64 system have that problem.......
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
    Jan1980's Avatar
    Nov 2014
    This problem is curious. I own genuine xprog and it works fine on my win7 64 bit. I have the same problem with genuine upa. I have to restart the system every time when i want to work with upa and press F8 to disable the driver sign..
    bram380's Avatar
    Indonesia +628153111774
    Quote Originally Posted by iamfooser View Post
    Hi guys,
    Go to device manager,
    check com port,
    if xprog appear "yellow color" it mean "usb driver problem."
    uninstall driver,
    referesh device,
    install again usb driver (old driver or new driver win7),
    done.
  9. The Following User Says Thank You to bram380 For This Useful Post:
  10. #8
    Oct 2016
    if you need - i can send you drivers for Xprog 5.6 Win7
    What version of XProg do you have?
  11. #9
    bram380's Avatar
    Quote Originally Posted by bumer View Post
    here all driver:
    - old driver winxp
    - new driver win7 32bits
    - new driver win7 64bits
  12. The Following 9 Users Say Thank You to bram380 For This Useful Post:
    dadal (25th December, 2023), daquima (23rd May, 2019), ecufix (31st August, 2018), electronicdeivi (19th April, 2020), Gery (19th September, 2019), iamfooser (16th October, 2016), marcin7091 (15th July, 2019), mariantv (23rd March, 2019), mikajna (23rd February, 2019)
  13. #10
    iamfooser's Avatar
    Sep 2012
    Problem solved. Use old version win xp driver on win 7 is fine.
    Thanks all!
  14. The Following User Says Thank You to iamfooser For This Useful Post:
    bram380 (16th October, 2016)
  15. #11
    dadal's Avatar
    Aug 2015
    I had same problem, firest disable the driver sign, and instal old xp drivers,,solved
    thanks Bram380
