Results 1 to 8 of 8
    Sep 2009
    Romania
    Default How to test Ford Denso navigation
    Hi!I need help ,this navigation have pover On button separate from main board and i want to
    turn On on bench.I conected 2x+ and 2x- but i guess can be turned on from CAN.I send pictures from back of radio.
    anybody have a schematic of pins?Thanks
    And one more thing ,the navi is with M serial,and code calculated with Ford M calc not good.Is this possible?
    Thanks!
    Feb 2010
    WALES
    Quote Originally Posted by attilaa0 View Post
    Thanks!
    Yes my friend, some DVD are M coded but are not M calc, read eeprom for true serial and code
    If M000??? then try M800???
    wbr
    Apr 2010
    post pictures of all labels (not only denso)
    Sep 2009
    Romania
    Radio is 5S7T-18B988-AC
    M003967 CD132-NAV-Module. code 7558 not work.
    ans Mechanism part number VP3M5F-18c821-DG
    serial CVM115061
    Feb 2010
    WALES
    serial CVM115061
    Did you try 4119 ?
    wbr
  6. The Following 2 Users Say Thank You to shooting For This Useful Post:
    attilaa0 (19th October, 2016), irfa (19th October, 2016)
  7. #6
    KierAn20's Avatar
    Sep 2009
    UK
    Thanks!
    Missing one important part buddy - navi drive from boot/trunk. This is more than just a disc reader, it has main function for driving that front end touchscreen unit.
    If you connect the Fakra socket at rear of your dashboard unit (2x+ & 2x-) it will only give power to the audio cd drive mechanism, nothing more.
    Hope that helps....
  8. The Following 3 Users Say Thank You to KierAn20 For This Useful Post:
    attilaa0 (19th October, 2016), shooting (19th October, 2016), Zapp (24th February, 2017)
  9. #7
    Sep 2009
    Romania
    Hi!I connected the navi drive,and the radio starting but say something like"The vehicle ID not mach,contact dealer."
    And before this message i see something like wait 30 but for one second before appear message. i leave the radio powered on with ignition key 30 minutes and message not disappeared
    and finally i guess somebody tried wrong codes.I do not know what to do.
  10. #8
    Mar 2013
    Hi. Is the navi DVD drive programmed to the vehicle, if so how can a second hand unit be reprogrammed. Thanks
