Results 1 to 8 of 8
Thread: Help needed adt
    Sep 2010
    Default Help needed adt
    Hi does anyone have the master code for a Adt domonial system or know how to factory reset thanks
    Meat-Head's Avatar
    Not, but as a rule the engineer codes on alarms are like
    4567 4444 5555 6789 9999 etc etc
    But if engineer code changed, as a rule bin it
    Sep 2010
    Ye tryed most of these but read that Adt use 6 digit codes so I've tryed 999999 etc I've got the user code and a tag but can't change anything in the system it's asking for a master code wasn't sure if you could factory default it but not sure how to thanks
    Meat-Head's Avatar
    Try looking under your thanks button, see if another label there
    Sep 2010
    Update I've got engineer codes and reset system however I think I've now completely messed it up now I've reprogrammed pirs but not figured out how to install tags and when try to arm system it just says operation cancelled any help .
    Meat-Head's Avatar
    No, but share the love on what the engineer code is and how you got it.
    think best bet find a bent alarm engineer
    Sep 2010
    Open domonial panel there is a button on tamper hold down for 3 seconds then within 30 seconds open keypad at the side of battery is a small button push in and hold for about 4 seconds panel will bleep ( if it dosnt repeat ) that now gives you engineer code 112233 master code as reset to 123456 you can now programme codes etc
    Meat-Head's Avatar
    Quote Originally Posted by ack1234 View Post
    thats great info, usefull info thanks,
