Results 1 to 8 of 8
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default bmw e65 3 faults need help
    bmw e65
    szl -swich center steering column
    2 faults
    94EA-communication between steering wheel and steering wheel amd(steering column module faulty)
    94E3-terminal U_ISIS or U_SZL missing
    this fault in airbag...
    93c8 deactivation :switch center,steering column
    all pushbuttons not work and airbag light on...
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    I change szl and all works ok but only 2 days...now again fault code 94E3
    Clamp U_Isis missing
    and 94EA comunication
    any ideas please....
    Oct 2015
    Hello,u solve the problem??
    DK Veteran bobbik's Avatar
    EUROPE
    Bump, have same problem
    immokill's Avatar
    Jun 2009
    UNIVERSE
    I saw this problem on youtube look on bmwforum
    Sent from my TELEFON
    Here to HELP!
    immokill's Avatar
    Jun 2009
    UNIVERSE
    Try to use inpa and see ocupacy sensor on seat mats or your airbag is gone unit is gone
    Here to HELP!
    Fec001's Avatar
    I have the exact same problem. any idea?
    I suspect the electronics inside the steering wheel, the little black box (PN.: 6 938 106)
    EDIT:
    The problem is the electronic black box inside steering wheel. If I heath that up, it works.....
    Nov 2024
    Quote Originally Posted by Fec001 View Post
    EDIT:
    Hi, i Have a similar problem. Do you mean your buttons work if you use something to heat the black box?
    To change it do you need to reprogram anything or just swap the little black box?
