Results 1 to 15 of 23
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default Mini Cooper S 1.6T R56 MED17.2 ecu clone 0261S04443
    Hello mates. I have Mini Cooper S 1.6T on Med17. Old ecu damaged, I have second hand used ecu, the same numbers, and want to clone it or get ISN from ecu dump and modyfing CAS dump to set new ISN them. First, please help me to get ISN. ECU read using KTag.
    20-read-int-flash.rar
    20-read-epprom.rar
    WinWoj's Avatar
    Jan 2012
    ECU City
    Any suggesting, mates?
    Gavra's Avatar
    Belgrade/Melbourne
    Use AVDI or Autohex, all over OBD and you will need working key to decrypt ISN. You must change ISN in CAS and align DME-CAS-ELV to get it working.
    Guided fault finding = Feature that many factory scan-tools have and real technician despise it.
  4. The Following 4 Users Say Thank You to Gavra For This Useful Post:
    BMWS1KRR (11th November, 2016), decno1 (8th November, 2016), doctore (8th November, 2016), WinWoj (8th November, 2016)
    WinWoj's Avatar
    Jan 2012
    ECU City
    Is it possible to do this steps without car, working only on files - open dump in avdi/autohex, prepare new files and write it into mcu's?
    Gavra's Avatar
    Belgrade/Melbourne
    As far I know it is NOT possible to do that without car, but maybe someone knows more and can point in right direction.....
    dijo's Avatar
    From cas it is possible to get ISN/SK with working key but from ECU only by OBD...
    bearheroes's Avatar
    Dec 2011
    Quote Originally Posted by WinWoj View Post
    Yes..........
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
    WinWoj's Avatar
    Jan 2012
    ECU City
    So, if i have new ecu, these dump I read is not usefull for you to sync? The most important thing is read Motorola mcs12 0L15Y, or something more?
  10. #9
    WinWoj's Avatar
    Jan 2012
    ECU City
    Anybody can help me? I understand not free... But i would like to start that car, it is frezed over one year and very important for me to solve that problem after all... Best regards
  11. #10
    fear_dark's Avatar
    Sep 2010
    send cas eeprom and new ecu eeprom dump i make sync
  12. The Following User Says Thank You to fear_dark For This Useful Post:
    WinWoj (10th November, 2016)
  13. #11
    WinWoj's Avatar
    Jan 2012
    ECU City
    Temporary i can't read it via upa... But i think it is computer issue, because in another laptop upa read mcu's but on actually used laptop still have errors. So i will try soon read it and send
  14. #12
    fear_dark's Avatar
    Sep 2010
    upa don't read..
  15. The Following User Says Thank You to fear_dark For This Useful Post:
    WinWoj (11th November, 2016)
  16. #13
    WinWoj's Avatar
    Jan 2012
    ECU City
    Yes, right. Device not respond, even if reset up... I will try xprog..
  17. #14
    lush29's Avatar
    Oct 2015
    Test back on the car after you try it to read with upa maybe you need an dump for cas also. You need better tools to do this. Like colleagues said above.
    Sent from my SM-G925F using Tapatalk
  18. The Following User Says Thank You to lush29 For This Useful Post:
  19. #15
    WinWoj's Avatar
    Jan 2012
    ECU City
    My Colleague send me immo off dump for this ecu, not sure is good, but we try. Then CAS maybe will not nescesery for car start...
