Results 1 to 11 of 11
    Aug 2016
    Default Micra k12 proximity
    Hi i need help anyone got solution with micra 2003 intelligent twists type . After batter dissconnect immo light on car and car not starting, tried avdi mvppro x100 few other tools . Key lamp goes off in programming mode then with ignition on come back on
    Please help if you know how to solve this car
    Aug 2016
    Non one for help
    Jan 2016
    Has the steering column been changed? If a secondhand one has been fitted, will start until battery disconnected or flat. When reconnected immobiliser kicks in because it doesnt match.
    Sent from my SM-G930F using Tapatalk
    Aug 2016
    Quote Originally Posted by Cr4nky View Post
    No we haven't changed steering column only battery when down and immo kicked in!
    Jan 2016
    Yes, but has it been changed previously? The problem wont surface until the battery either goes flat or gets disconnected. Seen it lots of times on these.
    Jan 2016
    Assuming you have already tried battery reset, ign on etc
    Aug 2016
    Yes i have and also checked all fuses relays etc
    Jan 2016
    What is fault code?
    Aug 2016
    What is fault code?
    I will upload the fault codes shortly however after this problem the ignition switch dosnt turn on the keyless side only when key is in !
    The dtc are below
    DETECTED MODULES
    Device No 0x01: ENGINE
    ECU PART NUMBER 8200326498
    DIAG ID 44
    SUPPLIER # 13533
    HARDWARE # 8200334419
    SOFTWARE # 00BE
    EDITION # 008C
    CALIB # 0F50
    OTHER SYSTEM 270503
    MANUFACTURE 80
    P0380: PREHEATING UNIT DIAGNOSTIC CONNECTION - CO
    Device No 0x02: ABS
    ECU PART NUMBER 47660-AX600
    DIAG ID 00
    SUPPLIER # ?2341
    HARDWARE # 43032924F6
    SOFTWARE # 658B
    EDITION # 0502
    CALIB # 0005
    OTHER SYSTEM 000000
    MANUFACTURE 82
    Device No 0x04: BCM
    ECU PART NUMBER 284B2-AX620
    DIAG ID 02
    SUPPLIER # 3231
    HARDWARE # 2167627203
    SOFTWARE # 0005
    EDITION # 0300
    CALIB # 0000
    OTHER SYSTEM 000002
    MANUFACTURE 80
    Device No 0x05: AIRBAG
    ECU DISCRIMINATED NO. A925
    Device No 0x12: ELECTRIC POWER STEERING (DAST 3)
    ECU PART NUMBER 48810-AX600
    DIAG ID 00
    SUPPLIER # B0418
    HARDWARE # 0000000000
    SOFTWARE # 6422
    EDITION # 0014
    CALIB # 0002
    OTHER SYSTEM 000000
    MANUFACTURE 80
    Device No 0x14: UNDERHOOD SWITCHING MODULE
    ECU PART NUMBER 284B7-AX600
    DIAG ID 00
    SUPPLIER # A0802
    SOFTWARE # 1400
    EDITION # 0000
    CALIB # 0000
    OTHER SYSTEM 000000
    MANUFACTURE 80
    U1000: CAN communication circuit - PAST
    Device No 0x20: SMART KEY LESS
    ECU PART NUMBER 285E2-AX601
    DIAG ID 02
    SUPPLIER # A0109
    SOFTWARE # 4408
    EDITION # 4D4D
    CALIB # 4555
    OTHER SYSTEM 000000
    MANUFACTURE 80
    B0006: NISSAN ANTI-THEFT SYSTEM MALFUNCTION - PAST
    B2014: STRG COMM2 - PAST
    Aug 2016
    after reset only fault dtc B0006 remains
    super jumbe's Avatar
    Livingstone
    Quote Originally Posted by garagetech007 View Post
    The battery discharging or being replaced shouldn't cause the problem you have but try inserting the key and switching the ignition on for 5 seconds, then switch it off, wait another 5 seconds and switch it on again, repeat this a few times and it should start.
    If not then there is a fault with the car system, I was told years ago I just remember, when you enter in the car with intelligent key system this car will only crank and start when you press foot brake, on this occasion when you press the foot brake the immo does not give you access to ignition switch to start the car therefore with manual key turning will not start the car because brake switch wiring is also connected to antitheft system.
    Try fitting new brake switch, all the best.
  12. The Following User Says Thank You to super jumbe For This Useful Post:
    WD40 (17th November, 2016)
