Results 1 to 15 of 22
    rex89's Avatar
    Not Near Tricore MCU
    Default NEED MED9.1 IMMO OFF
    Hello guys , please i need immo off for this ecu 0261S02145 from audi A4 year 2005 , i read already flash and eeprom by BDM
    thanks for all
    BR
    Imagination is more important than knowledge, because knowledge is limited ... while imagination creates the world.
    vlaki electric's Avatar
    Jan 2015
    serbia
    Quote Originally Posted by rex89 View Post
    thanks for all
    BR
    try with eprom only if not then write and flash to.i cant make cheksum on flash so you need only that,but i think is gona work in eprom only...
    0261S02145_off.rar
  3. The Following User Says Thank You to vlaki electric For This Useful Post:
    rex89 (24th November, 2016)
    rex89's Avatar
    thanks i try and post report tomorrow
    Nov 2016
    autolab
    You must bdm read the ecu in order to immo off. Reading just the eeprom will not work. You will need to merge flash|eeprom after you modify the eep contents and run a checksum correction on it before writing back via bdm.
    rex89's Avatar
    Hello guys , sorry for delay , car dont start , i try with flash and checksum correct no start
    South Africa
    You must not bdm eeprom ,use programmer to program eeprom,regards
    Do what you can with what you have .
    rex89's Avatar
    Ok no problem i try again for see
    South Africa
    Immo off on flash and eeprom, flash with bdm, eeprom with programmer
  10. #9
    rex89's Avatar
    hello guys , eeprom by programmer failed then flash by bdm after correct checksum and write eeprom by programmer failed too , car start few 4 sec and stop
  11. #10
    Sep 2016
    read eeprom and flash and post here i will make immo off ok
  12. The Following User Says Thank You to roro8 For This Useful Post:
    gigaby (22nd November, 2021)
  13. #11
    Sep 2016
    immo off ok 100%
    dont forget tell me and thanks
  14. The Following 6 Users Say Thank You to roro8 For This Useful Post:
    BrendanT (1st July, 2022), Djtroliz (18th April, 2017), MARIKO (3rd October, 2021), MonSter911 (7th March, 2022), reda75 (26th March, 2020), rex89 (10th December, 2016)
  15. #12
    rex89's Avatar
    Car start , thanks u
  16. #13
    leandroks's Avatar
    Brazil
    Hi guys could anyone help me on immooff
    Passat 2.0TSI
    Cheers
    BR
    Leo
  17. #14
    leandroks's Avatar
    Brazil
    anyone??? has foud solution???
  18. #15
    Gammoudi's Avatar
    Dec 2017
    ECUS
    .............. PASS AFTER THKX + REP
  19. The Following User Says Thank You to Gammoudi For This Useful Post:
    leandroks (17th November, 2020)
