Results 1 to 7 of 7
    Nov 2012
    Default ABS Repair MK60 BMW Mini ATE
    Hi guys,
    anyone have solution for DTC code C1DF5 (Unit Intern Failure) in ABS ECU ATE MK60 from Mini BMW?
    Thanks in advance
    motocarlos's Avatar
    Jun 2009
    Portugal
    Quote Originally Posted by chiptuner8 View Post
    Hi guys,
    Thanks in advance
    did you solve the problem from the ABS unit, i got the same problem.
    Regards.
    WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
    Dec 2019
    I found a damaged IC 9369.1D it has 14 pins and my one had the Motorola symbol as well as the word Ate 98. I have found and ordered a replacement from ebay and will report back when I repair it.
  4. The Following User Says Thank You to Sudnut For This Useful Post:
    tomvleeuwen (18th December, 2019)
    italy
    HI DIGITAL KAOS FRIENDS,I 'VE MINI WITH MK60
    5DF5 INTERNAL FAULT.
    LIKE YOU I 'VE INTERNAL FAULT BUT WITH CODE 5DF5
    I FOUND CHIP FALITURE FOR MOTOROLA 14PIN MAKING 9369.1D
    I'VE REPLACED WITH 9375.1B THET I FOUND IN OTHER MK60 ECU, NOT FOR MINI.
    ECU WORK FINE
    IN ATTACHMENT YOU SEE BROCKEN CHIP WITH THE REPLACED ONE.
    I HOPE THET IT WILL HELP ALL DIGITAL KAOS MEMBER FOR REPAIR THIS FAULT
  6. The Following 9 Users Say Thank You to fra69 For This Useful Post:
    aprilia40 (4th April, 2023), BusCan (5th May, 2020), jarek88 (9th December, 2022), Martin124 (30th April, 2024), motocarlos (28th January, 2020), oiknikos (1st March, 2020), pfemek (28th August, 2023), r1yamaha (14th June, 2021), zar0079 (29th January, 2020)
    Mar 2020
    please tell me the numbers from the units.
    i have the same fault in my 6759075 unit from bmw e46
    yours abs is now work>?
  8. #6
    Mar 2020
    Quote Originally Posted by fra69 View Post
    ECU WORK FINE
    is the abs work now.
    i have e46 with the same problem. i am reflow all the solders and its work for some days..now is dead again with 5df5 code.
    how to test the ic?
    the ic you use is from newer version unit? you thing is work and for me?
    sorry for band egglish and thank you!!
  9. #7
    POLAND
    ECU WORK FINE
    Hello.
    I had the same problem in Mini R50 - Steuergeraet ASC - internal error 5df5.
    Replacing the 9369 chip solved the problem.
    Thanks fra69 - good work.
