Results 1 to 3 of 3
    May 2009
    Default Opel Corsa C Airbag ECU pin out
    I have a vauxhall corsa c z10xe and the airbag light was on, fault is due to passenger airbag squib high resistance (7.3 ohm) according to opcom, driver side is fine at 2.8 ohm.. I went to check the passenger airbag/squib and surprisingly there is no airbag unit for the passenger side (seemingly this car was made with just ther driver side airbag present). I assume someone previous has installed an airbag ecu that is programmed for both front driver & passenger airbags instead of installing a single variant.
    Would anyone have the pin out for the temic SDM ecu (GM 24 439 954) and if so is it possible to introduce a 2.2 ohm resistor to the correct pin out wires on the loom to bypas this fault as the ecu variation cannot be altered?
    Thanks.
    May 2009
    After lengthy searches I found what may help me with my issue, sorry for starting a thead somewhat unnecessarily. But on the upside, here is the diagram I acquired in case it may be of any use to someone in the future:
  3. The Following User Says Thank You to Haed For This Useful Post:
    castin (25th April, 2019)
    Oct 2024
    Hi,did you resolve this issue i think i have the same problem i can see it was a while back but if you can remember it would be very helpful
