    Feb 2011
    Default Citroen C5 EDC16C34 dtc off P0238
    Hello
    I need to delete the dtc P0238 in the Citroen C5 1.6 HDI EDC16c34, thank you very much for your help
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Hello
    dont disable "P0238 Manifold absolute pressure sensor - Pressure too high" ! are little hard to repair that only from actual/real value !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    Feb 2011
    I can not deal with this problem, the car was repaired turbocharger and occasionally catch the error code, the car drivin 'well there's no problem, so I want to delete the dtc because the car will be sold and do not want to invest in it more
    And the new "owner" will be the lucky one !
    Full WinOLS user
  5. The Following 2 Users Say Thank You to mihaiservice For This Useful Post:
    bobolin4o (5th December, 2016), konq100 (4th December, 2016)
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    And his mechanic will be the winner too!
    Feb 2011
    problem solved, the topic is closed
