Hi Guys
I just bought OpenBox V9s yesterday and explored to see what the craic , first impression was good but there are too many unwanted channels is there a way to clean up and get something like sky have currently
I have come across two issue and the workaround as follows
a. Usually when trying to watch channels from FAV list had to select the Fav folder and then the Channel and pressing select or OK brings to the full screen
i . when try to change the channels using keyboard notice that the channel goes back to channel 001 not matter what channel you were in the FAV folder
Workaround :
select Ok on the remote then select the FAV list again and then click on the channel once and then Exit ( this is important) now you can change the channels
b. When the FAV channel list is big for example International the above workaround does't work it still goes back to channel 0001
Any idea how to fix this or move the FAV folder to upwards
