Results 1 to 8 of 8
    r_parev's Avatar
    Bulgaria
    Default Renault Scenic 1998 ecu 0281001809 immo off
    I did a test with "ImmDec3.2" and "Immo Cleaner 2" but without success. The car starts only once. Please some help.
    I returned the old dump and typed PIN code, but no car was started
    prusony's Avatar
    Belarus
    For diesel immo-off only with emulator!
    That dump prepared to emul. (PASS.)
    Cut 59 pin ECU !!
    Non ut edam vivo, sed ut vivam edo.
    kiszka's Avatar
    May 2016
    argentina
    Works 100%
    If I help you press thank you + reputation
    senic-immooff.rar
  5. The Following 10 Users Say Thank You to guille2016 For This Useful Post:
    Beno2500 (9th December, 2019), felix_fetche (25th January, 2017), fiflus (9th February, 2023), impuls002 (6th February, 2023), kenrique10 (23rd February, 2017), lluna (4th February, 2019), nandito (31st July, 2023), prusony (14th December, 2016), Rotor (23rd May, 2023), selwyn (2nd May, 2022)
    prusony's Avatar
    Belarus
    Quote Originally Posted by kiszka View Post
    can be immo off without emulator
    with your dump virgin
    Yes, engine start, but limited to 3000rpm.
    May 2016
    argentina
    Something wrong the file works perfect I always use it.
    Are you sure I cut pin 59 ??
  8. The Following User Says Thank You to guille2016 For This Useful Post:
  9. #7
    r_parev's Avatar
    Bulgaria
    Тhank you all. I'll try. The car is gone now. I removed the EEPROM and the car starts, but only up to 3000 rpm.
    guille2016 Does it need to change EEPROM in 24TS04WP or another
  10. #8
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    Far far away
    Change eep to 24c04WP or 24c08WP. Make eeprom write protect, lift pin 7 solder to pin 8.
    Cut pin 59, done.
  11. The Following User Says Thank You to lupu_sandu For This Useful Post:
    r_parev (14th December, 2016)
