HELP MPPS v16
I recently bought a MPPS v16 Cable online, i got it quickly but now i have a problem.
all of my pc?s are running Windows 10. but the program cant load in other than Windows XP.
please help me fix my problem.
best regards ME
HELP MPPS v16
best regards ME
daily drive (20th April, 2020)
From what I know operating systems it Must be Windows xp I heard anything higher was always a problem
tray in propertis from mmps icon compatibility mode put in xp sp3
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
Let me guess you have the shitty loader type mpps ? If yes then try this http://www.digital-kaos.co.uk/forums...9&d=1448718347 Works like charm for me.
Hi Mcfite.
Did you resolve this - I'm having the same problem trying to run MPPS V16 on windows 7. I have the loader type and its full of problems. Sometimes it will load and sometimes not and all crashes when I try to connect to the car.
are you running the program in compatibility mode?
ive had all these headaches with shitty 1.6 its in the bin now. v1.8 and v1.3 all the way. zero issues
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
be very carefull with MPPS. i bricked an edc16 with mpps.
make sure you have a full bdm backup!
Thank you EddieMoney!!!!
I used your suggestion and it worked.
I used MPPS V16 on Windows 10 64bit, your version with no loader. I had a few snags with the crappy loader version provided by the seller.
Make sure you run it on compatibility for Windows XP SP3. Make sure dongle is connected when you are running program or it will not run.
I have the same problem. But on win xp.. nothing work. I install fresh xp on laptop.. its need any software for work ? Net framework or something like that? Thank you guys.
Hello guys, hope someone can help me out...
I just got the MPPS V16 (clone) and i´m trying to read an ECU ME1.5.5 but i´m getting 2 errors:
One is: "Maximum Number of attemps reached" (cant remember the exact error words now, but is something like this)
The other is: "Invalid Key"
When i do the ECU INFO (F1), it gives me the VIN number and version, but when i press "Read" (F2), i get these errors...
Sometimes its the 1st, other times its the 2nd one.
And it always gives me the "Error Windows" to send Log.
Can anyone tell me that this might be?
I already tried several times to read this ECU with Kess V2, but i cant read it...
This is from a Mexican Chevrolet Model (similar to EU Opel Corsa C 1.6 8V)
If anyone can give me some tips i would really appreciate...
Just Consider helping Freely like I want to do...
Thanks and Rep are Always Welcome...
