Results 1 to 10 of 10
    Default W906 esp - variant coding problem
    I want change variant coding from rechtslenker to linkslenker in esp Mercedes Sprinter 906.
    I have das 2013 with Developer mode, I use function enriegelung but not working.
    Someone help me?
    Nov 2010
    BY
    need scn coding online or developer mode activ . entriegeln -
    unlock the block esp, there is no need . option steering , body variant long - midle - short .
    +4 options, all placed hands on the variant coding of the ezs
    team viewer 9 installed ? if so then 20 min of work . PM
    I have developer mode - no luck
    Dec 2016
    Dear Mr milkatrek,
    I wonder you have finished this problem yet, but i once faced this type of problem.
    To be certain, I live in Vietnam with left handed drive, and don't know how the esp ecu turn into right handed drive.
    I just enter variant coding, change the information.
    I make use of Mercedes Xentry-Das 7.2016
    Best Regards
    problem solved
    Moderator
    PremierD's Avatar
    Jun 2009
    Quote Originally Posted by milkatrek View Post
    problem solved
    Be good to know how you solved it mate ... to help those who come across the same problem
    Nov 2010
    BY
    online scn coding --> the only correct solution!
    You must unlock ecu by develpoer mode and change variant coding after that hard reset unit ESP - that all
    Just another solution .
    2007 Sprinter with same Variant coding error 4845 . Did changed MITTEL coding to LANG and error disappeared.
    Jul 2022
    Hello i need help.
    How do I unlock the ECU in a Mercedes Sprinter 2013 to change the coding variants in ESP.
    Now I try to do it, an error pops up in DAS and DTS Monaco.
