Hi, does anyone have the airbag wiring diagram for a Fiat 2009 500c twin air? The airbag ECU is Continental 51897810.
Many thanks.
Many thanks.
24 way connector A
Pin 1 Ground
Pin 2 +12
Pin 7 Can H
Pin 8 Can L
it can always be useful to a person seen that I did not find on the forum
Just a little thanks
danielif (9th July, 2022)
hi. anyone connect this type module on bench? I try FIAT ECUSCAN with and w/o yellow conector and its not ok , can connect say canbus fault.
So pin 1 ground pin2 +12 pin 7can L pin8 Can H no 12v on pin 14
ECU 51897810
Confirmed
Don't forget to press the THANKS & REPUTATION button for help in the future.
BusCan (15th November, 2022)
danielif , can you explain " 12v on pin 14" ? and did you use yellow plug and FES or directly any other scanner?
Here is a diagram of a Fiat 500 AirBag
Good luck
atomiczen (12th November, 2024), ilen (1st May, 2023), laurentiudania (20th June, 2024), marmaro (19th November, 2023)
Have you managed to communicate with the AirBag unit Me impossible
Hello. I have same problem with this ECU 51897810 , no working diagnosis on car and on table. Any idea how repair sensor or
what elements are damaged?
BR
