Results 1 to 15 of 19
    Dec 2015
    Default help X5 E70 CAS 3 My car does not start
    I wanted to change the km of my X5 after doing my meter I did the CASE 3 and since the car no longer takes the key ya no more contact nor it starts someone can watch my dump if not corompu
    9S12X
    61.35-01471906-01
    2073180892
    5WK4 9514OBRCASX5.rar
    Dec 2015
    Qestion if the 35080 is badly welded this can make its?
    And if I do not plug the meter its can start or have contact
    Car will start with dash disconnected so problem lies in cas unit
  4. The Following User Says Thank You to diagtech For This Useful Post:
    nono93 (21st December, 2016)
    Dec 2015
    Ok, so even if the meter and unplug the car must start
    How can I make for the case?
    Its can repair?
    epd1221's Avatar
    Nov 2011
    usa
    so car starts with meter unplug friend???
  7. The Following User Says Thank You to epd1221 For This Useful Post:
  8. #6
    Yes car starts with meter unplugged upload data from cas may have damaged flash
  9. The Following User Says Thank You to diagtech For This Useful Post:
  10. #7
    Dec 2015
    Thank you for your answers !!!
    What's the best solution for me!
    Buy a case 3 at BMW or I can recover an ocassion or repair mine
  11. #8
    salkapone's Avatar
    Oct 2013
    what tool you use for making odo in cas ...and post photo of sticker fom cas with info maby we found same flash for you if is crushed or repair eep if is damaged....check small plug on cas that is first thing what you need check,,,,an see maby you make some short circ when you solder wire in cas,,,
  12. The Following User Says Thank You to salkapone For This Useful Post:
  13. #9
    Dec 2015
    OK,
    Thank you here is the photo of case3 for reading I used a motorola pro (tool provided with DIGAPRO)
  14. #10
    salkapone's Avatar
    Oct 2013
    i see isn and vin in cas is o.k,also i see first two keys is stored in cas,,,i think we need to find flash,,,can you make conection for diag in cas trough obd ,,,you can try ,,first turn on lights constantly for wakeup cas,,,if you cant make diag flash is crushed
  15. #11
    salkapone's Avatar
    Oct 2013
    i dont have flash for this part number ,,,ask for help here on dk for flash,,, or if you have comunication with cas you can find someone with ISTA/p than try to reflash your cas
  16. #12
    Dec 2015
    Ok so how can i read the flash
  17. #13
    Dec 2015
    How to read the flash ????
  18. #14
    Dec 2015
    Ok somewhat a solution for me my problem
  19. #15
    antenor's Avatar
    Here
    R270 read this CAS Flash and eeprom.
    If i help, d'not forget to press thank button!!
  20. The Following User Says Thank You to antenor For This Useful Post:
