Results 1 to 15 of 16
    Member kevin33140's Avatar
    Nov 2016
    Default alfa romeo gt 150 cv tune
    bonjours a tous
    quelqu'un peut me faire une mod +20 % sur on fichier alfa gt 150 cv 16v 1037379006 merci beaucoup
    si possible egr off mais pas obliger .
    ori kevin.rar
    Andrei2015's Avatar
    Oct 2015
    Please use English language mister
    Stage 1,2,3, DPF+EGR+SCR+FLAPS+TVA+CAT (all off)
    VAG ME7 LC+ALS+NLS+2step, VAG MED9.1 LC+ALS+NLS, EDC17 LC+HARD CUT
    POPS & BANGS (Schubabschaltung, Crackles)
    Nov 2016
    Sorry ANDREI2015
    Hello everyone
    Someone may make me a mod + 20% on the file alfa gt 150 cv 16v 1037379006 thank you very much
    If possible egr off But not oblige.
    pawelelectro's Avatar
    Jun 2011
    Disconnect EGR plug.
  5. The Following 3 Users Say Thank You to pawelelectro For This Useful Post:
    bruno1989 (7th January, 2017), kevin33140 (8th January, 2017), konq100 (7th January, 2017)
    Nov 2016
    [QUOTE = pawelelectro; 2926576] 183hp 384NM sur dyno.
    Bouchon EGR D?connecter.
    [Attach] 419791 [/ attach] [/ QUOTE]
    I try and I tell you that. Thank you
    Nov 2016
    Pawelelectro I have a question for your file.
    The egr addresses are in 1c30e8 and 1c356c normally?
    Why are not it changing?
    I already have an egr off file of a friend for my gt and have the addresses 1c30e8 and 1c356c which have been modified.
    Are you on your file?
    thank you very much
    Mar 2013
    There are few ways to disable EGR.
    In my opinion 1c30e8 and 1c356c are the worst of them
  9. The Following User Says Thank You to patolini For This Useful Post:
  10. #8
    Nov 2016
    Can you develop why this is not the right way ^^
    Sorry I'm trying to learn
  11. #9
    Nov 2016
    If you want to post the edit file of my friend with egr off to have your opinion
  12. #10
    Sep 2016
    Quote Originally Posted by kevin33140 View Post
    Hello, closing manually the EGR on these maps will get a not enough air related DTC.
    On Fiat Alfa there are better ways.
  13. #11
    Nov 2016
    OK so may be why my idle is an unstable ?
  14. #12
    Mar 2013
    HW issue. Injectors, dual mass flywheel, engine mounting
    For me correct way to disable EGR is switch or histeresis.
  15. The Following User Says Thank You to patolini For This Useful Post:
  16. #13
    Nov 2016
    thank you powelelectro good file
  17. #14
    Nov 2016
    and thank you patolini
  18. #15
    Nov 2016
    HELLO first thank you for the file of my gt again
    My friend will like you to increase his power from 190 to 200 cv + egr off. it's possible ?
    Thank you again if I can help you one day it will be with pleasure
    https://mega.nz/#!bNgwGYJI!NJ25-D4zQ3dvY5dcjRODMprVRRZnysYKhHj1EqIix1c
