Results 1 to 15 of 16
    Jan 2017
    Default Peugeot Boxer 2010 - Factory fitted Bosch radio / CD says 'Cancheck'
    When I first got my van, I swopped the very basic factory fitted radio / CD with a Kenwood unit which is great. I want to transfer the Kenwood to my next van.
    I replaced the original radio and have got the message 'Cancheck' on the display. I have the radio code etc, however the useless handbook makes no mention of how to enter the code. Anyway I suspect that the word 'Code' should be displayed for the process to start.
    I spent hours on the phone to Peugeot dealers (8), Peugeot UK, Peugeot Fleet, Bosch Automotive UK and the supplying dealer - all useless and some even telling me that vans don't have radios - Muppets
    I've trolled this forum and seen some dialogue on this topic but no difinitive answers. Can anyone help please.
    Many thanks
    WALES
    Quote Originally Posted by CamperVanMan View Post
    Many thanks
    Is your radio the Original radio for your van or just the same model?
    wbr
    Jan 2017
    yes - The Bosch 'Passport' booklet with the radio codes etc refers to it as a 250CD
    WALES
    Did you reconnect all plugs back into the radio?
    I say this because it shouldn't display Cancheck if it's the Original radio
    wbr
    Jan 2017
    I believe I have but will remove again and reinsert again - there were three blocks - Top includes earth and canbus etc, the middle block is speakers and the bottom block connector is something to do with the steering wheel controls I believe.
    WALES
    The bottom should be power and a few other things
    wbr
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Try diagnose via Diagbox and post result.
    Scripts for Multi-PROG
    Best regards.
    Dragon
    Jan 2017
    Thanks for the feedback so far - excuse my ignorance - what's a digibox?
    dragon100's Avatar
    Jan 2012
    It is diagnostic equipment dedicated for Peugeot/Citroen cars. Did you try disconnect battery ?
    Best regards.
    Dragon
    Jan 2017
    I'll Check the wiring again tomorrow when it's light and report back. Here's the wiring diagram for my radio.. Cheers
    Jan 2017
    No good idea - I'll disconnect the battery and then check the wiring and see if that clears things
    Jan 2017
    Default Still Stuck
    I disconnected the van battery and left it for an hour - I reconnected the battery and switched the radio on - 'cancheck' was back . I've spoken to a few Fiat and Peugeot dealers again today but no solutions suggested.
  13. #13
    KierAn20's Avatar
    UK
    Has the van ever been in to a dealership for a service etc SINCE you fitted the aftermarket radio? I suspect there is no signal on the CAN lines and just needs to be reactivated using either Diagbox, as dragon100 mentioned, or Planet2000 at a dealership (much more expensive option).
    Basically you need a local autospark who has Diagbox in his armoury (most will have this because it is essential these days). They can plug in and include the oem radio in the CAN network again.
  14. #14
    dragon100's Avatar
    Jan 2012
    Sometimes Launch X431 or Easydiag with new all functions do this job, try with this equipments and write again car vin number on the radio ...
    Best regards.
    Dragon
  15. #15
    Jan 2017
    Thanks everyone - I'll try get a local auto electrician to reset as suggested. Cheers
