hi there dear members. is it possible for some kind member to assist me on coding used abs mk70 control unit. vehicle is a vw 2k caddy. the original abs control unit is defective, no com. original abs control unit part number is 1K0 907 379 P. the replacement abs control unit part number is 1K0 907 379 N. the current coding from the secondhand unit is 0017025. the following fault codes are stored in abs controller. 01044 control module incorrectly coded. implausible signal.. 2nd fault code is 01044 control module incorrectly coded. mechanical failure. the coding Is applicable to the jetta 5 1k. the proper coding according 2k caddy must me 0017106. I have tried changing coding, but vcds reject the coding. could any member please assist me. many thanks in advance,
