Page 1 of 3 123 LastLast
Results 1 to 15 of 35
    Jan 2017
    Default EDC17CP14 read/write over obd2
    Hi, I am beginner in this ecu world. I would like to tune my car but i don't know if it is possible over OBD port. found some stuff online that it is possible with mpps V16 clone but I am not sure. I need to buy tool for flashing so this is the reason why I ask, I would like to buy some kind of clone, obvious reason $$$
    Pic is scan from VCDS
    Aug 2012
    Quote Originally Posted by daci View Post
    easy all car with edc17cp14 before 9/2009 you can write over obd no problem . same with softwareupdated ecu the tuning protection is everytime the same.
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    Jan 2017
    If I understand from this vcds scan is visible that ecu is flashed 17.09.2014. does that mean tuning protection is on now?? which tool do you recommend to buy ??
    Aug 2012
    look at the car build. is it before 9/09 you can write . the flash date is only last update
    car before 9/09 you can write over obd
    car before 9/09 with update to 2017 you can write over obd no tp active
    car after 09/09 you can read but write is luck :-) only boot is safe or ori tool
    best buy kess 5.017 with 2.22 you can do many cars
    and a k-tag for tricore
  5. The Following User Says Thank You to icezero2010 For This Useful Post:
    daci (30th January, 2017)
    Jan 2017
    My car is 2008 so it is perfectly safe to read and write...i would like to buy mpps v16 clone because it is cheap and don"t neeed it for other cars just for mine. To sum up things I can buy clone of mpps v16 read and write perfectly safe with it over the obd port ??
    Aug 2012
    Than buy kess v2 with old Firmware its better
  8. The Following User Says Thank You to icezero2010 For This Useful Post:
  9. #7
    Jan 2017
    Can I mess up something just with reading ?
  10. #8
    Apr 2016
    You'll only mess something up if your laptop or car battery dies.
    To be safe have laptop plugged into mains and if have one to hand, your car battery hooked up to a charger pack.
  11. #9
    Apr 2011
    mandoria
    I advise you not to write this ECU obd safe method is to write in the boot with fgtech
  12. #10
    Jan 2017
    thank you, than it will be fgtech or kess...but I am not happy, for every flash you need to open ecu
  13. #11
    Sep 2014
    Use search button or google, you will find how to open ecu without damage It's not a hard work, only need some time and patience
    galletto v54 is good for beginning, you will find it for about 50$, not a big deal
    i never use obd r/w for edc17
  14. #12
    Aug 2012
    You dont Need Open this Ecu you can Write with kess No problem. Galletto is Not so good it kills sometimes the eeprom.
    I'm 100 % sure that work if Not i repair your Ecu for free
  15. The Following User Says Thank You to icezero2010 For This Useful Post:
    chli1976 (31st January, 2017)
  16. #13
    Jun 2009
    With the NOx update an such car TP is also not changed.
    So i can write cars before 9/09 with NOx update also over OBD
  17. #14
    Aug 2012
    Yes u can i have test many cars all Cars that have No tp get no tp with update
  18. The Following User Says Thank You to icezero2010 For This Useful Post:
  19. #15
    Jan 2017
    that is useful info can I get full backup over obd if something goes wrong or do I need to have backup from bootmode ?
