Results 1 to 5 of 5
    UK
    Default Citroen SEDRE problem
    I have just installed Citroen service back up & SEDRE. Its on a Windows 7 64 bit machine.
    The doc backup program is working perfectly but im having an issue with SEDRE.
    It appears to have installed ok & starts up, I can select a vehicle but when I try to open a diagram I just get a The file xxxxxx.svgz is not available screen.
    I've done a fair bit of googgling on this & there are loads of different problems but I cant find this one anywhere.
    Any one have any ideas ?
    Apr 2011
    i have same problem and need help thainks
    May 2016
    install svg viewer from left toolbar and use IE 8 cheers
    Poslano sa mog F3311 koristeći Tapatalk
    UK
    Quote Originally Posted by Juxa View Post
    Thanks for the reply. I have already installed SVG viewer but are you saying it wont work with anything after IE 8?
    May 2016
    Quote Originally Posted by the_big_d View Post
    hi, im think not, try your best, cheers!
