Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
  1. #16
    Quote Originally Posted by einet View Post
    its a genuine Beeprog2 and paied 1200€
    Ouch!
    Expensive mistake.
  2. #17
    gopelhu's Avatar
    EU
    How have pinouts for soic adapters for the Beeprog2?
    All Elnec products (like beeprog,beeprog+,beeprog2...etc) with 48pins connector are the pinout up to 48pins to pin1 to pin1....... pin48 to pin48.
    Which soic ic do you need to read/write? I have some original adapters with protel 99 se pcb files.
    Regards,G
  3. #18
    Youneselm's Avatar
    Nov 2010
    Quote Originally Posted by gopelhu View Post
    Regards,G
    Hi mate,
    Could you share all those and post them here?
    That wil be so awsome and kindfull.
    Thanks in advance mate.
    Br
  4. #19
    einet's Avatar
    This info help many members, me also.
    Try to read 93c46 or 56 not read error on some pins.
    35080 not read also
    95080 not read erro on pins
    95160 not read error on pins
    i lost all what i can not read, i use Carprog or UPPAs to read eerpoms
  5. #20
    antwnhszr's Avatar
    macedonia is greek....
    i have BEEPROG 2 original from elnec and is very good and stable programmer.the true is for the adapter's and the ISP programming it's litle coplicatated.....
    reard's
  6. #21
    Regards,G
    Not correct - as I stated they changed the pricing model to make more $$$/???/<insert currency here>
    http://www.ebay.co.uk/itm/BOTTOM-TSO...MAAOSw2xRYTtMz
    Here is the bottom part of one of there TSOP48's. No need for a 48pin - but see the extra block and the eeprom/other chip infront of it. This maintains the count of the number of times used and the elnec software uses this to refuse to work after limit reached.
  7. #22
    gopelhu's Avatar
    EU
    Quote Originally Posted by Youneselm View Post
    Hi mate,
    Br
    Hi mate,
    here are and enjoy !!!!
    I removed the attchen files bec nobody give me the thanks or....
    Regards, G
  8. The Following 2 Users Say Thank You to gopelhu For This Useful Post:
    handmade (29th July, 2022), toms4 (31st March, 2019)
  9. #23
    gopelhu's Avatar
    EU
    Quote Originally Posted by SunRise View Post
    This is only NOR flash I hate this NOR flash adapter...
    I said the all 27,28,29F flash to pin1-to pin1....and NOT a NOR flash ....
    Regards, G
  10. #24
    cubica1's Avatar
    Feb 2012
    Serbia
    I can't believe what I'm hear here...I have Beeprog orig from Elnec (ok..it's discontinued tool) ..it is fantastic tool, but now..ISP tokens, soic8 adapters are not 1:1 ?? I just can't believe, what's happen to Elnec, they will loose a lot customers on that way. Sadness.
    regards,
    cuby
  11. #25
    Youneselm's Avatar
    Nov 2010
    Hi mate,
    Regards, G
    Good work mate!;-)
    Press Thank and Reputation If info was helpfull.
    Always there to help people
  12. The Following User Says Thank You to Youneselm For This Useful Post:
    gopelhu (15th February, 2017)
  13. #26
    murat332's Avatar
    Türkiye
    hello friends
    i have beeprog2
    i have MT29F64G08CABA nand flash
    it has some settings, how can it be
  14. #27
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by murat332 View Post
    hello friends
    i have beeprog2
    the real question is : what are your trying to do??
    as your screenshot is pretty straight forward if you ask me
    if you need a password, "you" need to PM me after pressing thanks and rep, i will never send it to you unless asked in PM by yourself..!!
  15. The Following User Says Thank You to ricked For This Useful Post:
    murat332 (25th February, 2025)
  16. #28
    murat332's Avatar
    Türkiye
    Thank you very much ricked
    problem solved
