Results 1 to 7 of 7
    ascrap2003's Avatar
    Sep 2016
    Texas
    Default 2016 Tundra Mileage Location Correction
    2016 Toyota Tundra Dash, BCM?
    93C66? Algo?
    Any one mess with one yet? Pics of board, pointers, cluster removal yadda yadda?
    ascrap2003's Avatar
    Sep 2016
    Texas
    Come on some one has to have a 2016 dump I just wanna make sure, any way if anyone hasn't done a 2014 and up yet I'm doing one and will upload dump when i'm done, also if you need cluster removal direction look up hypertech speed sensor/calibrator filter thingy it has a good write up on cluster removal. Pretty similar to 2013 Tundra
    Dec 2010
    what tool you use?
    Its msop 8 do you know how to read this eeprom?
    ascrap2003's Avatar
    Sep 2016
    Texas
    Quote Originally Posted by rukartinatv View Post
    what tool you use?
    USA Prog programmed as C66 Toyota Tundra Option worked like a charm had to reset maintenance no biggie chip is right on back of board don't need to remove needles
    ascrap2003's Avatar
    Sep 2016
    Texas
    Attachment 426900 as promised here is the dump for DK member pleasure!
    ascrap2003's Avatar
    Sep 2016
    Texas
    Quote Originally Posted by ascrap2003 View Post
    Lots of acetone, cotton swabs, pick tool and patience! hate the coating stuff, whats it called again? This one was blue tougher than normal clear stuff
    May 2017
    Did you took some pictures?
