Results 1 to 15 of 20
    Feb 2017
    Default Husqvarna Nuda 900 Immo EWS Issue
    Hi everybody,
    After an attempt to start my bike in cold weather and low battery, bike is stuck with the message EWS in the dashboard.
    I pass the first details of the diag but battery, relays, fuses, antenna ring OK
    I have a cable K + DCAN OBD USB and software Rheingold ISTA/D, ISTA/P V3.55 and other standard tools 2.12.
    With ISTA/D I was able to recover the error codes that were:
    009324 KOMBI: Undertension ==> Corresponds to the low voltage of the battery at the time of the worries.
    00E509 Instrument panel: CAN message (from the DME) missing
    I was able to erase the error codes and none returned. I first thought (not excluded yet) that the DME had taken a blow of juice apparently possible when we insist on the starter. But I can enter the functions of the DME and for example start the fan. I also have test to disconnect the ring antenna and I immediately get an error message which I can erase.
    Wanting to see the info of the keys I launched ISTA/P and after scan I get the message. "Problem with EWS. (KOMBI) is not configured correctly (No key has been learned) It is therefore not possible to guarantee correct processing with ISTA/P. Contact BMW Motorrad for further information)
    I read on other threat that keys data are stored in Dash: 25C160
    Several questions:
    - Is it possible that nothing is "burnt" but that all keys have been erased from memory?
    - Is it possible that a component is burnt? If yes in the DME or the KOMBI?
    - In ISTA/D all info is not present, VIN, mileage, color code ... OK; But for engine, gearbox ... there is written Unavailable. Is this normal?
    PS: Another rider has a similar problem with the same motorcycle and took him to the Husqy / KTM concess. Their answer: We will change the DME, it will cost 1200 ? and 10 weeks of waiting.
    Sorry for long story and thank you for your help
  2. The Following User Says Thank You to Kr33per For This Useful Post:
    Firefight3r (25th July, 2022)
  3. #2
    gepakg's Avatar
    Serbia
    post dump from dash 25lc160 inside will tell you more about problem,and also key info 4d-80bit
    regards Gepa
    Quote Originally Posted by Kr33per View Post
    Hi everybody,
    Several questions:
    PS: Another rider has a similar problem with the same motorcycle and took him to the Husqy / KTM concess. Their answer: We will change the DME, it will cost 1200 € and 10 weeks of waiting.
  4. The Following 2 Users Say Thank You to gepakg For This Useful Post:
    cjawahir (13th February, 2017), Kr33per (14th February, 2017)
  5. #3
    Feb 2017
    Quote Originally Posted by gepakg View Post
    regards Gepa
    i'm like a Newbie in this field but I'll learn. Already have the raspberry, I will buy a test clip and see what I can do.
    I also have PN532 NFC Reader. Is it ok to read key info?
  6. #4
    gepakg's Avatar
    Serbia
    if you are newbie in this field NUDA 900 is not for playing,trust me :-)
    also if you are newbie in this forum you have thank`s button if somebody help you or reputation to make comment of useful post
    regards Gepa
  7. The Following User Says Thank You to gepakg For This Useful Post:
    doctore (10th February, 2017)
  8. #5
    Feb 2017
    Yes I know it can be risky but because BMW sale the brand to KTM. The only answer is:
    "We don't know what's the problem. We'll order a new ECU for 1200€ and 10 weeks waiting"
    And if the problem is in the KOMBI that'll no work...
    Juste to be sure. Is it possible that the eeprom has been erase or corrupted by attempting to start the bike several times in few secondes/minutes with low battery?
  9. #6
    gepakg's Avatar
    Serbia
    yes,very rare but possible...immo (ews) is inside dash
    regards Gepa
  10. #7
    Feb 2017
    I can't find any info about the DME/EWS Alignement on this bike if there is any to do. Nothing in ISTA/D as for cars or R1200 bike.
    maybe Synchro is back to "0" when battery is removed for enough time and then it's not required to do an alignement with software.
    Maybe we can have the answer if someone know the procedure to replace the dash? (Should be similar on Husqvarna Nuda, Terra, BMW C600 & C650)
    When replacement dash ordered to factory is it configured and plug&play?
    If I buy used Dash with associate keys will it be plug&play?
    i'll try to answer that before going further with eeprom.
    Thanks again for your help
    Edit: If someone has a good tutorial to read eeprom with raspberry it will be great.
  11. #8
    gepakg's Avatar
    Serbia
    dont waste time,i told you second time post dash eprom i will told you everything what happen :-)))
    also you must find `` thanks `` button :-))
    regards Gepa
  12. The Following User Says Thank You to gepakg For This Useful Post:
  13. #9
    Feb 2017
    Just ordered an EZP2010 programmer. It'll take at least 2 weeks to come from China.
    I'll send eeprom dump as soon as I get it. Th
    Thank you for your time Gepa.
    Really appreciate it.
  14. #10
    gepakg's Avatar
    Serbia
    in most cases in dash is microchip 25lc160 and can be read/write with many other tool`s as UPA,X-prog,seeprog,etc...few min.job
    regards Gepa
  15. #11
    Feb 2017
    I opened the dash and the eeprom is a microchip 25L160BE.
    Just to be sure is it the same as 25LC160?
  16. #12
    gepakg's Avatar
    Serbia
    yes
    regards Gepa
  17. The Following User Says Thank You to gepakg For This Useful Post:
    Kr33per (23rd February, 2017)
  18. #13
    Feb 2017
    Thanks Again,
    While waiting for programmer can you explain to me what is the relation between eeprom 25L160 and MCU MC9S12 also in dash.
  19. #14
    gepakg's Avatar
    Serbia
    ohhhh my god :-))))) you ask for something that should be answer that you don`t understand nothing,try first with simple things,my friendly opinion...
    regards Gepa
    Thanks Again,
  20. #15
    Feb 2017
    I know and I'm feeling bad but But what can I do?
    I have a 6000€ bike that doesn't start.
    i tried to contact garage and here are the answer:
    BMW: "Not our Problem".
    KTM says: "We can't help you"
    Husky says: "We can't help you"
    I changed the battery, checked Relai connector and transponder Antenna. I did scan and test with Ista.
    So I have no choice now. I need to try and ask questions (maybe dumb) to learn and understand.
    I did read a lot of forums, sites, watch videos. If you have more please give me links. I'll be happy to read more.
    Once Again, thank you for helping. really appreciate as I'm feeling quite lonely.
