Results 1 to 15 of 17
Thread: CDR 2005 Panel
    Romania
    Default CDR 2005 Panel
    CDR 2005 radio which shows "PANEL" on the display
    I have the code but just can't get prompted to enter it, have tried everything ie, radio off - ignition on - hold down AS button as I'm switching on radio- that didn't work. Tried holding down number 6 while turning it on that didn't work. As I turn it on and off it's saying 10SAFE or PANEL.
    Oct 2013
    Ukraine
    Code Entry as Follows:Switch On Ignition (No Need To Start Engine)Turn Off StereoPress & Hold Preset " AS " andSwitch Radio On - Display Shows" SAFE " And Then Shows " 10 - - - - "Press preset " 1 " repeatedly for 1st DigitPress preset " 2 " repeatedly for 2nd DigitPress preset " 3 " repeatedly for 3rd DigitPress preset " 4 " repeatedly for 4th DigitIf the correct code number is now shownPress & Hold Preset " AS " Until the Unit Beeps-------------------------------------------Read 24с16 reset attempts
  3. The Following 3 Users Say Thank You to masterskay62 For This Useful Post:
    asliyucegsm (5th May, 2023), KierAn20 (16th February, 2017), mcd76 (16th February, 2017)
    KierAn20's Avatar
    UK
    Quote Originally Posted by ghita_gsm View Post
    Does serial number in c16 dump match serial number etched into radio chassis? The only time I seen this happen on a VDO CDR-2005 is when somebody has put dump from a VDO CDR-500 inside it instead. Message on screen is because it can't sense the security panel (removable keypad which all CDR-500 radio have) is present.
    So it can be that dump not original, OR ..... there is corruption in the original dump which makes it look for a removable security panel. Either way, you need to change the 24c16 dump and it will not show the "Panel" error buddy.
  5. The Following User Says Thank You to KierAn20 For This Useful Post:
    Meat-Head (16th February, 2017)
  6. #4
    Meat-Head's Avatar
    Rumor statez the panel is coded to the radio
  7. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    KierAn20 (16th February, 2017), things4u2get (8th July, 2019)
  8. #5
    UK East
    Panel could well mean the front panel is not plugged in correctly and thinks its missing..
    Just re-read above, it shouldnt be saying this as its a cdr2005 so i concurr with KierAns20.. drop the dump and lets have a look at it..
  9. #6
    May 2023
    Greece
    I have the same problem on screen its show PANEL after a keep pressed AS button and power on, the display has change to 10SAFE and do nothing with 1,2,3... memory buttons.
  10. #7
    Nov 2010
    Hello.
    I think the invalid counter is overflowing
    code entry attempts. Reset attempts and check after
    this.
    And post your dump.
  11. #8
    May 2023
    Greece
    how i can reset attempts? i have change firmware but nothing.
  12. #9
    Nov 2010
    And post your dump.
  13. #10
    WALES
    Quote Originally Posted by stratakis View Post
    Use original firmware and press "ON" and hold "AS" until beep...
    Post original firmware for code
    wbr
  14. The Following 2 Users Say Thank You to shooting For This Useful Post:
    irfa (5th May, 2023), REZON (5th May, 2023)
  15. #11
    May 2023
    Greece
    Default Original firmware
    Ok this is the original Firmware of my cdr 2005
  16. #12
    Jul 2021
    code.........1397
  17. #13
    May 2023
    Greece
    So i must program the original firmware and use code 1397, only that will be reset the attempts and give me a permision to enter the code???
  18. #14
    Mar 2016
    Try code off..............
  19. The Following User Says Thank You to Mankyro For This Useful Post:
    petronijul (5th May, 2023)
  20. #15
    Jul 2013
    your file is code off (1397)
    try this file and enter code 1397
  21. The Following 3 Users Say Thank You to petronijul For This Useful Post:
    MAKSIMUS (6th June, 2024), Mankyro (5th May, 2023), stratakis (9th May, 2023)
