    Nov 2011
    Default Mercedes W212 - 2009 / engine power loose after changing km.
    Mercedes w212 / E klasse / 2009
    WDD212003.... / 250 CDI
    Programming km with DP4 without problems.
    But after few miles, problem is that the car just doesnt have the power it used to be
    Before programming the km, car drive with original power, no problems at all !
    I read out "P246397 - The soot content of the DPF
    is not OK"
    * I erase fault, but fault come back after 10 minutes, even without turning the engine !
    * Replacing mechanically the complete DPF , same problem !
    So programming km is causing extra problem....
    Any idea's how to solve this specific problem ?
    thanks for any tips.
    Mar 2011
    EU
    I always reset mass soot and initialize DPf replacement with star diag and it work
  3. The Following User Says Thank You to Ocin For This Useful Post:
    CARPARTS (17th February, 2017)
    Xentry->Coding->replace dpf filter
  5. The Following User Says Thank You to pandora6 For This Useful Post:
  6. #4
    Feb 2011
    balkans
    Or make dpf regeneration with xentry,hawe this situation couple days ago
    Послато са B3-A30 уз помоћ Тапатока
  7. The Following User Says Thank You to star10 For This Useful Post:
  8. #5
    DUPNICA BULGARIA
    Try this solution next time: Start engine-car at idlle and then make kilometers.
  9. The Following User Says Thank You to ilian_cho For This Useful Post:
    CARPARTS (18th February, 2017)
  10. #6
    brend's Avatar
    Oct 2015
    Same where
    Quote Originally Posted by CARPARTS View Post
    is not OK"
    Do dpf regeneratsion .after regeneration pretsedur ECU take actual km by dash for next regeneration servis calculating that`s all.
