Results 1 to 15 of 25
    Feb 2017
    Default non start Nissan micra 12 2005
    Hi everyone,
    I am newbie in this forum, i hope you professionals will try to help me with my nissan micra 2004 keyless system, my son bought his first can which turn out to be sour for him and my self, basically it is non starter and my mechanic used his diagnostic machine got code P1611 Natts malfunction, everything works fine i mean all light comes on on the speedo but nats light does not turn off. the engine does not turn at all so basically its in comma! tired to power starter motor and it works fine, also sent ECU for testing and it came fine the locksmith checked the key fine too. after that got another complete kit but still the same situation, i did not change the
    power steering which i feel its built with natts too, or codes do not match. now i am confused where to start from i would not mind paying someone for his time but i need this car to be started, ill also be happy if any one could advice me so can try to sort it, but i am no computer genius ,
    please please help me guys
    Gdansk Poland
    check fuses in engine fusebox under left lamp.
  3. The Following User Says Thank You to adiagnostyka For This Useful Post:
    naikey (23rd February, 2017)
    Jul 2014
    Under the fusebox "engine conparment" there is few releys, one of them is faulty. Good luck.
  5. The Following User Says Thank You to goran13 For This Useful Post:
  6. #4
    Aug 2014
    Yes, check relays in engine compartment. Was there at anytime cam or crank sensor faults? Can you see engine speed?
    Sent from my SM-G900F using Tapatalk
  7. The Following User Says Thank You to Tyson500 For This Useful Post:
  8. #5
    Feb 2017
    Default non Start K12
    Quote Originally Posted by Tyson500 View Post
    hi thanks for your response, all fuses and relays are fine i dont know if power steering is coded , the car car was non starter from beginning, got another complete ECU kit from scrap yard but unfortunately i did not get power steering coloumn that is where i feel
    its stopping the car from cranking. all lights show on speedo red light with key symbol stay on and the car is dead, doors light they work fine but no start or turning engine.
    any chances of maching power steering module.
  9. #6
    Gdansk Poland
    find someone witch diagnostic scanner and reed codes. If you start changing components you go in hight cost with small chance to find real problem.
  10. The Following User Says Thank You to adiagnostyka For This Useful Post:
  11. #7
    Feb 2017
    Quote Originally Posted by adiagnostyka View Post
    hiya,
    did check all the basics the clock shows milage perfactly did also disconnected power steering but it is still the same fault code reader says P 1611 immobiliser malfunction. fuel pump relay also activating but somewhere something is stopping.
    help please
  12. #8
    Jan 2016
    Yes steering column is coded. That will be your problem. If they are ever changed on these with secondhand unit, the car will run until battery disconnected or goes flat.
    You need to rewrite eeprom in module with virgin file, then it will self code back in.
    Sent from my SM-G930F using Tapatalk
  13. The Following User Says Thank You to Cr4nky For This Useful Post:
  14. #9
    Feb 2017
    Quote Originally Posted by Cr4nky View Post
    hi
    thanks for your responce, by disconnecting steering coloumn is it not possible to start the car, or other way way to check engine if its working fine?
    Alsoany one around london who can help me. with this as am not computor guy myself. would not mind paying for his time ?
    regards
  15. #10
    Jan 2016
    No, not possible to just unplug.
    Did you buy it as a non-runner?
  16. The Following User Says Thank You to Cr4nky For This Useful Post:
  17. #11
    Feb 2017
    hi,
    Yes the car was non runner i have gone through hell. with stupid car, i took to dealers n the bite me hard could not start the car, then i sent ECU to recheck and it came not faulty. after that i bought complete kit but without power steering , calld for key guy to check same thing. getting fault code P1611 immobiliser malfunction.
    only recently i found out on micra is 04 reg and on steering coloumn the sticker dated 05 so now i am 100% sure the code is not maching.
    i am no computor genious to i dont know about eeprom things and dump files. so basically i am planning to open EPS and solder new chip 24C16 and finger cross
    it works as been asking here any one could help but not getting responce.
    off course not for free.
    thanks for your reply as its giving me a bit of hope
  18. #12
    Jan 2016
    You might get better response if you used the thanks button to thank the people who have helped you.
    I can send you correctly programmed eeprom, but if you are not used to doing this sort of thing, could get out of your depth.
  19. The Following User Says Thank You to Cr4nky For This Useful Post:
  20. #13
    Feb 2017
    sorry i cant see thanks button here please guide me. but i whole heartedly appreciate all the people who are trying to help. only if someone around london area would help to reprogram the power steering it would be great.
  21. #14
    Feb 2017
    hiya sorry i cant find thanks button here !
  22. #15
    Feb 2017
    hi
    By correctly programmed eeprom , means what a ready program chip, which is just to solder on the board ?
    thankx
    mate!
