Results 1 to 15 of 18
    Jul 2016
    UK
    Default HU87/HU133R Suzuki Ignis/Vauxhall Agila B Picking
    Just a quick question has anyone on here picked one of these?
    I have the Mr Li tool and I'm unable to get any binding or progress on this, never had any issue with other Lishi/Mr Li tools. Anyone have any advice?
    Many thanks.
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    practise
    and gut lock
    Dec 2010
    Nottingham
    yup , your flogging a dead horse for want of a better term.
    Most of The HU87 door locks have a set up that prevents you from getting any binding wafers at all .
    the ignition picks and decodes very simply but not the doors , there are some old lock versions that do pick but most you will see on doors will not.
  4. The Following 3 Users Say Thank You to rapidlocksmiths For This Useful Post:
    kronk92 (28th November, 2021), rm23 (12th April, 2020), truedetective (20th February, 2017)
    Jul 2016
    UK
    Quote Originally Posted by rapidlocksmiths View Post
    Top man. Cheers!
    Aug 2010
    Australia
    Mr. Li is fully aware there are some Suzuki door locks with side bar, that explains why you do not feel any binding for these locks. It is not a tool problem.
    I have encountered these locks a couple of time in my country and air wedge seems the only way at this stage.
    Mr. Li is trying making a reader for these locks but it seems difficult because of the wafer structure preventing reading correcting.
  7. The Following 2 Users Say Thank You to jamesnz888 For This Useful Post:
    p1et (21st February, 2017), phuckyall (14th March, 2017)
  8. #6
    Dec 2010
    Nottingham
    makes you wonder why manufacturers ever moved away from side bars as effective means of security . most common older locks to see with these side bars that prevent picking is , VAC102 door locks , SX9 door locks , HU87 door locks and fiat ignition locks .
    some are suceptable to scope reading , other methods are find entry by alternate means and pick and decode ignition , order codes or remove and strip after airbag entry
  9. The Following 2 Users Say Thank You to rapidlocksmiths For This Useful Post:
    nazz2 (21st February, 2017), phuckyall (14th March, 2017)
  10. #7
    camelgd's Avatar
    Jan 2011
    South Illinois
    US Saturn had side bar door locks that could be decoded with Mitchell EZ Reader type of tool, the tumblers could be measured without picking. I have not run into Suzuki around here, nonexistent in Midwest US, but perhaps tumblers can be measured without stripping lock.
  11. #8
    Aug 2010
    Australia
    Quote Originally Posted by camelgd View Post
    Hi Camelgd
    We actually received requests from USA locksmiths about these Suzuki locks with side bar, and a sample lock from them.
    Luckily these locks can be removed easily after opening and key code is stamped on the lock.
  12. #9
    sdnatlst's Avatar
    Aug 2011
    England
    Had this today, no wafers would bind on door lock
    i wedged open door and managed to wind down window
    i put lishi in igniton lock, again nothing would bind, BUT with tension, the wafers bounced to the correct heights, decoding the lock without picking.
    blade i made worked first time.
    First time i picked HU87, had me stumped for some time, wish i searched DK beforehand haha
    Tools owned -
  13. The Following 2 Users Say Thank You to sdnatlst For This Useful Post:
    rob h (30th March, 2020), smokey08 (31st March, 2020)
  14. #10
    Aug 2010
    Australia
    Now Original Lishi has the HU87 reader for both door lock and ignition, no matter it is sidebar or normal cylinder. This is particular good for the door lock with sidebar for which normal 2in1 will not work. You now can just read and cut a key for the door, checking up with Instacode for the ignition cuttings.
  15. The Following 2 Users Say Thank You to jamesnz888 For This Useful Post:
    rm23 (12th April, 2020), sdnatlst (30th March, 2020)
  16. #11
    Dec 2010
    Nottingham
    the new reader works very well in the door lock on these , simplified the job alot , another success for mr li
  17. The Following 3 Users Say Thank You to rapidlocksmiths For This Useful Post:
    kleidaras (12th April, 2020), mikajna (12th April, 2020), sdnatlst (30th March, 2020)
  18. #12
    sdnatlst's Avatar
    Aug 2011
    England
    Just ordered the Mr li 87 reader.
    Make life easier on the next one.
    How many wafers are in the door on these?
    Tools owned -
  19. #13
    Aug 2010
    Australia
    Quote Originally Posted by sdnatlst View Post
    the new HU87 reader can read up to 10 wafers, 8 on the door lock and 10 in the ignition, it works on normal cylinder and sidebar cylinder.
  20. The Following 2 Users Say Thank You to jamesnz888 For This Useful Post:
    p1et (31st March, 2020), sdnatlst (31st March, 2020)
  21. #14
    mikajna's Avatar
    Mar 2015
    Which is new model, is that HU87/HU133 V.2 or is something newer?
    I never buy hu87, and can you place image of latest model for these locks.
    Послато са SM-A505FN помоћу Тапатока
  22. #15
    Dec 2010
    Nottingham
    Quote Originally Posted by mikajna View Post
    nw keys have it https://www.nwkeys.co.uk/Product/ori...tion-door-boot
  23. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    mikajna (13th April, 2020)
