Results 1 to 11 of 11
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    Default Removing Toyota Speed Limit ?
    can some one plz tell me how to get rid of the speed limit on a toyota Quantum it is almost same as the hilux D4D
    they started to limit it at 100Km/h and customers are not happy with it . i spoke to the tech at toyota and he say their is a way but do not want to tell the secrete , and he is also "scared" to diable the speed limiter
    so where in the ecu is this "limiter" set can i slap out the eeprom and chop it there or is there more to this ? personaly i would load a virgin file and redo injector coding and then sync immo to ecu if it is in the eeprom or is there a wire to cut on the ecu from the abs ?
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
    Aug 2016
    WELLINGTON CAPE TOWN S.A
    Quote Originally Posted by jakesman View Post
    Unplug the cluster if it come from the speedo I think,then you must find the wire you must cut,I will see if I can find out,
    Sent from my SM-T231 using Tapatalk
    Aug 2016
    Sorry you must drive without the cluster plug in
  4. The Following User Says Thank You to wimpieha For This Useful Post:
    jakesman (21st February, 2017)
    jakesman's Avatar
    Oct 2013
    nice one , plug the cluster out , the customer will not like that one , i know on old vw lt i know when u pull the fuse for wipers there is also no more limit and also no more wipers , i have read somewhere to pull the fuse for TCS (traction controle ) also customer do not aprove of this but there must be a wire from abs that tell the ecu it is going above 100km/h
    i am sure here on DK there will be a answer soon
    Aug 2016
    Well if it come from the abs ,unplug one wheel sensor the abs will not work ,take it now for a drive,hope it help
    jakesman's Avatar
    Oct 2013
    customer complain about abs light "ON" no m8 there is a correct solution for this i will beg and bribe at the stealership and will soon find a solution and for sure i will put it up here on DK
    Jan 2012
    EU
    Maybe it is possible to tune limiter from ecu? If there is bdm port in Quantum ecu (read/write with toyota ecu flasher? kess?)
    or one possibility is maybe use piggy back controller (unichip,apexi..) to clamp the speed input signal. If there is separate speed sensor input pin in engine control module (like in old toyotas).
  9. The Following User Says Thank You to Aajii For This Useful Post:
    jakesman (23rd February, 2017)
  10. #8
    hi, have a solution PM me.
  11. The Following User Says Thank You to g0tcha For This Useful Post:
    shanektm450 (5th April, 2019)
  12. #9
    Member satriawr's Avatar
    Mar 2016
    Jakarta, Indonesia
    Just remove the speed limit code from the ecu. Easy.
  13. The Following User Says Thank You to satriawr For This Useful Post:
    rtbdiagnostic (17th December, 2020)
  14. #10
    Quote Originally Posted by satriawr View Post
    Hello can you give me your skype please ,I need more info about this speed limit removing
  15. #11
    May 2015
    Interest to remove limiter on 2018 camry. Is also possible
    Quote Originally Posted by walter1 View Post
