Results 1 to 8 of 8
    Feb 2017
    Czech Republic
    Default Octavia 1.6 TDI CR 77 kw erro P0087 and P229A
    I have problem with Octavia. Usually when coming to up of hill car is going to "safe mode". If turn engine off and on, again works right.
    Error code P0087 and P229A.
    Already changed senzor on rail and pressure regulator on rail and fuel filter.
    Any idea what to do?
    Thanks for your help.
    Daniel
    Jan 2016
    may be fuel pump, or intaiking cup of pump is in wrong plase, and when You go up to hill - fuel go awey from pump
    Portugal
    Hello
    Did you change the fuel regulator and do you adjust the regulator?
    check fuel filter if black change it.
    these never last till service
    HELLO, DID THIS RESOLVE, HAVE SAME CODES AND SAME ISSUES, SAME 1.6TDI CR
    Mar 2016
    ireland
    change the fuel rail and fuel rail pressure sensor , check pressure sensor ohms reading must be 4-6 ohms anything outside this bad ..... had this many times fuel rail and sensor fix...
  7. The Following User Says Thank You to marty35 For This Useful Post:
    b44ly (11th April, 2019)
    had new rail with frps still throwing limp. i suspect wiring to frps
    i_shot_the_sheriff's Avatar
    Nov 2008
    Did you solve the problem eventually ? I have exactly the same problem .....
