Results 1 to 7 of 7
    Mar 2017
    Default Ford Escape 2005 9S12H with Digiprog 3 V4.94
    Hello Friends, Anybody can tell me if i can Modify the odometer in the dash for Ford Escape 2005 with Digiprog 3 V 4.94 ? . It has a 9S12H Motorola Processor. if be possible which connector i need and where i need to solder on the dash?
    Thanks.
    clusters's Avatar
    Mar 2015
    Canada
    A little searching would have given you all your answers, and that is in the Digi manuals that are posted all over the web.
    You need to rewire your ST48 first so the colors are right.
  3. The Following 2 Users Say Thank You to clusters For This Useful Post:
    buga37 (5th July, 2017), mapacherick (19th March, 2017)
    Mar 2017
    This procedure for HCS12 works for my 9S12H?. my cluster is slight different but i think that i found the port. after i rewire my connector i need to plug in the car to energize the cluster to read or digiprog do this with the wires?
    clusters's Avatar
    Mar 2015
    Canada
    No, you don't need to plug the cluster in. But if it won't read the old mileage properly, DO NOT try and change it.
    Mar 2017
    it works. thank you so much CLUSTERS. i finally use my digiprog 3 , thanks for your DB25 diagram, my 48 connector have different colors, but your diagram was so useful for me. i read with DIGIPROG in EEPROM Mode MCU. and then i make a backup , later modify throght Car/truck Menu.
    Work Great!!!!
    clusters's Avatar
    Mar 2015
    Canada
    Someone that listened and actually used their head to make a backup first. Good job
    For future reference, here is the wiring for all plugs.
  8. The Following 6 Users Say Thank You to clusters For This Useful Post:
    BYTES (19th March, 2017), j81 (20th March, 2017), Johnner (19th March, 2017), mapacherick (19th March, 2017), samux (27th August, 2018), wokcz (30th March, 2017)
  9. #7
    Mar 2017
    Thanks CLUSTERS, This information is Gold to me.. Thanks
