Results 1 to 8 of 8
    DashProg's Avatar
    Jan 2013
    Here
    Default Best universal programmer
    Please I want buy genuine universal programmer some advice mates
    Everything will be back in order - All my respects to DK's members.
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Depending on your needs, best chioce is 48 pin driver.
    Every programmer have it's prons and cons
    In example with conitec galep5 you can use any adapter produced since they start company.
    Welon vp990 from weilei (chinese) have inexpensive adapters.
    Beeprog or beeprog+ form Elnec very good ( don't buy BEEPROG3 very expensive in USE you can find some info here on DK)
    Xeltec 3000u good programmer (obsolete)
    I personally had all of above
    I bought 3000u from production line with many adapters and used for few years. Very good programmer in my opinion.
    Galep5 very compact have it's own power ( batteries), very good price. Some adapters expensive because it use old adapters from galep4- 40 pin driver and this adapters have some internal logic. But you can find some schematics on internet, in example 48tsop to 40 dil, and make it on your own .
    Welon vp990 inexpesive chinese programmer. Adpters in very good price in example tsop56 to dil 48 around 120EUR
    BEEPROG or BEEPROG+ very good, new line of programmers from ELNEC like BEEPROG3 is very expensive in use every adapter is intelligent and have some electronics and counter.
  3. The Following 2 Users Say Thank You to Faraday For This Useful Post:
    amigokola (21st March, 2017), DashProg (21st March, 2017)
    Second to Faraday, avoid less than 48-pin ZIF programmer, personally it's my top piority. A few of the most common memory used in old day auto-ECU are PSOP 44 and TSOP 48. If the programmer is of 48-pin ZIF there's high possibility that any of them, they use universal (1:1) pin mapping adapters. But if they're 40 pin ZIF for sure it must be of their own mapping whether 40 to 44 or 40 to 48. Think about when the programmer needs to be upgraded !
  5. The Following User Says Thank You to Zmann For This Useful Post:
  6. #4
    Oct 2016
    What about batronix bx48 batego II ?
    http://www.batronix.com/shop/program...batego-II.html
    Thanks for feedback
  7. The Following 2 Users Say Thank You to Topaze For This Useful Post:
    DashProg (2nd April, 2017), salimscan (4th May, 2017)
  8. #5
    dimet's Avatar
    MKD
    For me the best uni programmer is CONITEC GALEP 5 http://www.conitec.com/
    I have also CONITEC GALEP 3 for lpt port ................
  9. The Following 2 Users Say Thank You to dimet For This Useful Post:
  10. #6
    Moderator
    PremierD's Avatar
    Jun 2009
    then try fleabay mate ,, not DK
  11. The Following User Says Thank You to PremierD For This Useful Post:
  12. #7
    DashProg's Avatar
    Jan 2013
    Here
    Quote Originally Posted by PremierD View Post
  13. #8
    dimitar's Avatar
    Beeprog clone ....cheap and use it for five years without problem support 50.000 devices
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  14. The Following User Says Thank You to dimitar For This Useful Post:
