Results 1 to 5 of 5
    Feb 2017
    Default Nissan Tiida NATS 2 problem - P1614 (Chain of IMMU? key)
    Hi All,
    I have a Nissan Tiida here at shop, after successfully programming the key I can start the car about 3 times then about the 4th time the car cranks only and key light comes back on. I believe it is the NATS 2 that is rejecting the key.
    Faulty Code: P1614 (Chain of IMMU? key)
    Replaced the ECM, BCM and IMMO Reader Ring and still no luck.
    Any help would be much appreciated!
    code P1610 not stored?
  3. The Following User Says Thank You to okura For This Useful Post:
    masterlocksmith (31st March, 2017)
    Feb 2017
    Before programming key code p1610 was present, after programming key and clearing faults p1610 was cleared
    Mar 2017
    saudiarabia
    dear friend this codes mean your transonder in key is not working or must be reprogrammed
    so reprogramm it and it works
    or make immo off
