Results 1 to 3 of 3
    Mar 2017
    Default Ducati Hyper821 - ECU Magneti Marrelli - CAN LINE error
    Hi guys, I'm Trung, from Vietnam,
    my bike got a serious problem - CAN LINE error, hope you will support me to fix this issue.
    One month ago, I got the error "CAN LINE" on dashboard, all light flashing, fan turns on, push start button but not working, the bike totally dead ! Then I open the dash, I see the IC CAN Transceiver "TJA1040", I had replaced it, the bike lives again, everything works perfectly!
    Now I get the same problem, I thought cause IC CAN, I replaced it but the bike still dead ! I use multimeter to measure the CAN bus (without battery), each node the same 59.2ohm, the resistor is fine!
    The dashboard shows :
    + DTC ( Ducati Traction Control): "---"
    + ABS : "---"
    + RPM bar : flashing
    + Engine temperature : "---"
    + Speedometer : "---"
    + All light flashing
    BUT : when I unplugging the ECU,
    + ABS : "2"( 2nd mode ABS)
    + speedometer : "0 km/h"
    So I think my ECU got the fault, but I don't know what is the fault ! Thank you for your help will appreciate.
    PS: When I unplugging the fuse of ECU then re-plugging it, the dashboard seems received signal CANbus in 1 second ( DTC, ABS, engine temperature) then everything fault again. So my idea maybe the power of ECU fault , IC driver control fuel pump fault, etc...
    My ECU uses st10f296 chip
    Mar 2017
    Could anybody help me ?
    Aug 2016
    i ever see this problem before
    ever led flash snd push bottom bike cannot start
    i can fit it
    Bkk Thailand
