Results 1 to 15 of 23
    motocarlos's Avatar
    Jun 2009
    Portugal
    Default BMW E46 320D error 42 after change engine, help.
    Hello all,
    a mecanic friend have change the engine from a BMW 320D E46 from 2001, and now the car wont start, just start the starter and no star engine.
    Always keep the error 42 in the engine ecu, only have the delphi diagnostic tool.
    Please someone can help to tell what to do? immo off maybee? realigment?
    Regards.
    WORK WITH KWP 2000+, GALLETO 1260, BDM 100, FLASTEC CLONE WITH MAGPRO2, VAGCOM, FIAT ECUSCAN,UPA USB, MAXIDIAG, TOP 2049, PROG EXPRESS, AND MORE....
    dijo's Avatar
    Error 42 = Knock sensor
    M8 make real diagnosis, to understand what is going on...
  3. The Following User Says Thank You to dijo For This Useful Post:
    Stelaras26 (15th May, 2020)
    motocarlos's Avatar
    Jun 2009
    Portugal
    Quote Originally Posted by dijo View Post
    The error 42 says eprom/internal error
    Enviado do meu GT-I9195I atrav?s de Tapatalk
    Sep 2013
    garage
    read dde 3 eeprom 24c04 and post here
  6. The Following 2 Users Say Thank You to Mr BLACK For This Useful Post:
    DomnulNegru (12th April, 2017), motocarlos (13th April, 2017)
    Sep 2013
    garage
    some cars start with this error (42 eeprom or coding) some not ...but a commun fail is injetion pump ecu and for this car there is no fault code generated
  8. The Following 2 Users Say Thank You to Mr BLACK For This Useful Post:
  9. #6
    motocarlos's Avatar
    Jun 2009
    Portugal
    Quote Originally Posted by Mr BLACK View Post
    sorry for late, but here it is 24C04 ori.
    ECU : 0281010205 7 786 887/2247073/7789553
    DDE 3
    Please try to help me.
    Regards.
  10. #7
    Oct 2015
    T
    Quote Originally Posted by motocarlos View Post
    DDE 3
    Regards.
    Just make dme-ews sync
  11. The Following User Says Thank You to Tedum For This Useful Post:
  12. #8
    Sep 2013
    garage
    try this and raport
  13. The Following User Says Thank You to Mr BLACK For This Useful Post:
  14. #9
    motocarlos's Avatar
    Jun 2009
    Portugal
    try this and raport
    Ok,thanks,i will try and report back.
    Regards.
  15. #10
    Dec 2013
    [ATTACH] 442841 [/ ATTACH]
    I have a problem is identical. Please, help me.
  16. #11
    Sep 2013
    garage
    Quote Originally Posted by richardos47 View Post
    upload file again
  17. #12
    Dec 2013
  18. #13
    Sep 2013
    garage
    try this and raport
  19. #14
    motocarlos's Avatar
    Jun 2009
    Portugal
    try this and raport
    Hello again,
    Now The car start with your file, but it make very Black smoke and have one error from injection pump.
    Maybee its better change The pump from old engine?
    Regards.
  20. #15
    Jun 2013
    EU
    Hi.
    Have similar problem, car was working (customer said) and suddenly stopped. Now on diagnose error 42 and error 8. Car no more start.
    Here eeprom and flash read from the ecu, is possible any of them got corrupted? Now trying to clone both flash and eeprom on another same numbers ecu to see if really ecu got defective as error 42 says.
    please check if possible corrupted and can fix.
    Car is far away from here so in the meantime i will try to clone and check the scrapyar ecu in car.
    Regards,
