Results 1 to 8 of 8
    WinWoj's Avatar
    Jan 2012
    ECU City
    Default Opel Insignia 1.6T [A16LET] no power after engine swap..
    Hello. I have Opel Insignia 2009 A16LET after engine swap in previous shop, they can't find no power issue. I logged engine under load, 5th gear (has 6), from 50km/h with gas pedal in floor... turbine "lights" after few minutes of driving - so hot. MAF signal high, turbine make 0,8..1,2 boost, after cat disconnect no difference...
    WinWoj's Avatar
    Jan 2012
    ECU City
    Bllinda's Avatar
    Baltic
    Make a snapshot of Tech2 and placed here.
    And what kind of error ECU module
    today
    A topic that interests me
    WinWoj's Avatar
    Jan 2012
    ECU City
    Quote Originally Posted by Bllinda View Post
    the problem is no ecu error, but i using some ecu data to solve wrong ecu managment. I borrow MDI but now i can't show that data
    WinWoj's Avatar
    Jan 2012
    ECU City
    Hello guys, problem solved. It was magnetic ring on crankshaft from Astra, because engine was a from Astra to Insignia. But Ecu remain from Insignia. There is a difference between crank ring Insignia A16LET and Astra A16PET. That difference is TDC mark is three tooths shift. I have photo with compared this rings, also their numbers different, '781' and '780'. Unfortunately i don't make oscilloscope screenshot in good set, but i made logs, which i public soon.
    WinWoj's Avatar
    Jan 2012
    ECU City
    This picture shows how the magnets are set when two rings are in the same position. 3 tooths mean 18 degrees if I good understand... Next time I show good logs with fault comparison.
  7. The Following User Says Thank You to WinWoj For This Useful Post:
    maybach_ (5th December, 2022)
    Member goosebartek's Avatar
    Jan 2012
    Mosina
    Hello
    I have the same problem - did you replace only the pulse generator on the shaft? 55555803 / 55574780 did you also have to replace the camshaft ?
    Mar 2024
    Quote Originally Posted by goosebartek View Post
    Hello
    I have the same problem as you had. Swapped the engine on my insignia A16LET with Astra engine. I have no power and turbo red. I also have error P0344. Could you please tell how you solved the problem. Thank you.
