Results 1 to 15 of 18
    Dec 2014
    chiapas
    Default help ecu jeep liberty 3.7 2007
    Hello, I need help, I have a problem with the ecu of a jeep liberty 3.7 2007 automatic, which does not activate the relay asd, nor does it start. And check all the wiring and everything is ok and also the relays as well as the ipdm that is ok, the code of failure that I have is the P0688, when connecting the relay with cables direct if the pickup starts, but does not remove the warning light. Fault and follows code P0688.
    Has to be an electronic fault within the ECU, and check the voltages of the MPC 5554 and I have 5, 3.3, 1.5 and 2.5v. Which according to the freescale data sheet are the ones that arrive, but fails to communicate the ic MC33888 that the switch has 4 high sides and 8 low sides that are the relay asd and others.
    I also noticed that I have no clock pulse from the micro quartz resonator MPC5554. But this is fine, it's as if a part of the MCU logic is not activated.
    I can enter the diagnostic by scanner I can start the truck (with jumper cables) but it does not remove the fault codes in dashboard and it does not eliminate the P0688.
    vanos batam's Avatar
    Batam-Indonesia
    Hello..
    Can you reading MPC ??
    Dec 2014
    chiapas
    Quote Originally Posted by vanos batam View Post
    Hello..
    YES reader. dump to ktag
    clusters's Avatar
    Mar 2015
    Canada
    Checked Fuse 24 15A in the PDC? That is the circuit that feeds power from the ASD to the ECU.
    Dec 2014
    chiapas
    Quote Originally Posted by clusters View Post
    If the fuse 24 is fine, and the B + lines reach the pins of C1: 10 and 29 of ECM OK
    clusters's Avatar
    Mar 2015
    Canada
    Sorry, my diagram hard to read, should be Fuse 26. This feeds 12V back to the ECU at 3 different locations from the ASD, not the B+ lines.
    I'm sure the ECU uses one of these locations to monitor the ASD output and may be the source of your code.
    clusters's Avatar
    Mar 2015
    Canada
    Also you should be aware that the ECU needs a cam signal to activate the ASD. If you jumper the relay it may run without the cam signal but will be harder to start.
    Dec 2014
    chiapas
    The fuse 26 is that of the output relay which connects to the positive of the 6 ignition coils and the ECM C1: 38, C3: 19, 28. but only can reach these pins when the asd is activated satisfactorily. This is all ok
    Dec 2014
    chiapas
    Batam-Indonesia
    Quote Originally Posted by guzmancillo View Post
    post the dump please,,
    your Ktag is orig ??
    Dec 2014
    chiapas
    Yes, the micro reading is complete and the ktag is a clone but make several complete readings without errors and compare them separately and are correct
  12. The Following User Says Thank You to guzmancillo For This Useful Post:
    vanos batam (17th April, 2017)
  13. #12
    hass42's Avatar
    Aug 2012
    USA
    I agree with Clusters, check erratic cam and crank signals.
    Hass42
  14. #13
    Dec 2014
    chiapas
    signals CKP and CMP OK,
  15. #14
    Batam-Indonesia
    Default NGC5 READING PROBLEMS
    I never done reading this ecu..
    tried 4 pcs ecu/pcm 3.7 0r 3.8
    always got mess " micro protection removal "
    _______________ D3-oToprog _________________
    ig : vanos_batam
  16. #15
    Batam-Indonesia
    MATE!!
    do you have a full flash from 3.8 this ecu ?
    br
    ig : vanos_batam
