Results 1 to 12 of 12
    Hampshire
    Default Audi A4 remote programming procedure pls
    Hi all
    This was a lost key on audi A4, 8E, 2003, petrol, decoded lock, made a normal and remote key programmed the keys but i tried to program kd900 remote via the door method, with no luck, has anyone got the correct pocedure please?
    i have an original remote comming, i have avdi and ad100, if its programable via obd or is via the door?,tanks
    p1et's Avatar
    Oct 2013
    VCDS or manual procedure:
    1. Ignition on with 1st key
    2. Close the door and turn to lock position with second key
    3. Press unlock on remote (once if u want save remote on 1st position, twice if 2nd position etc. Indicators should flash after pressing unlock.
    4. Wait 5-6 seconds and press unlock again. Doors should unlock and lock. Remote is programmed.
  3. The Following 2 Users Say Thank You to p1et For This Useful Post:
    CaioW (21st April, 2017), nazz2 (18th April, 2017)
    Hampshire
    I went tro all the remote in the KD menu, with above procedure, mybe kd problem, will try the original remote 8ZO 837231 or is it 8ZO 837231D? Thanks
    p has nyone done A4 with KD on above model year?
    p1et's Avatar
    Oct 2013
    2002-2004 with 8Z0 ... D or you can program new shape from A4 B7 (8E0 ... K/Q)
    Hampshire
    Thanks mate,dont have vcds,but i have ordered 8ZO837231, dont have th other ones that you have mentioned, i was hoping to hear that if any one done one with KD.will report back ,cheers.
    Dec 2010
    Nottingham
    ive done by keydiy in past but only via diagnostics , i havnt used keydiy for a long long time on these as went back to too many where they just stop working , always recoded back in but then stopped working again, so always use oem on these now as hate call backs. these were years ago so may well be that the bugs are fixed now , interested to know if case as if so may give them another go.
    ive had issues getting remotes to code in on these a4 with advanced diagnostics in past some would work some would not , though always straight in with vcds.
  8. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
  9. #7
    Hampshire
    looks like i have to buy vcds! thanks for the heads up.
  10. #8
    melbourne, australia
    vcds is the go. I sometimes cant get them in with avdi but never have an issue with vcds
  11. #9
    Hampshire
    Thanks cqae mate, I am shopping around for vcds now, as you said, handy for A3 and A4 remotes.
  12. #10
    Mar 2018
    UK
    Quote Originally Posted by rapidlocksmiths View Post
    What model KD is suitable for A4 2007?
  13. #11
    Oct 2018
    Northern Ireland
    KD won’t do A4 2007
  14. The Following 3 Users Say Thank You to Jimmy07 For This Useful Post:
    amigokola (27th April, 2020), Manta1600 (27th September, 2019), nenadgorgi (27th September, 2019)
  15. #12
    scotland clydebank
    Vcds is a must for vw skoda audi and Seat best tool I have ever bought and lots of updates.
  16. The Following User Says Thank You to godfathertre For This Useful Post:
    Manta1600 (28th September, 2019)
