Results 1 to 3 of 3
    MarcinSalvage's Avatar
    Feb 2017
    Default Diagbox Peugeot 308 T9 fault codes
    I have recently runned a diagnostic scan to my 308 SW ACTIVE year 2016 and got a problem with deleting these two faults:
    ECU : COMBINE_UDS?
    Response data
    R59020990035409
    Fault codes
    B1003 54 : Secure configuration fault
    characterisation of the fault. : Absence of calibration
    Status . : present
    cause : local
    Variables associated with the fault
    ECU : BSI2010
    Response data
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
    Fault codes
    U1F00 00 : Fault event not stored in the faults log
    Characterisation : -
    Status : present
    cause : local
    Does anyone know where is the problem with this ERROR? I have to say that the car had many more faults but they are all gone except these two and I'm really out of ideas...
    Could anyone help?
    TuningHEX
    ADBlue/DPF/EGR/EVAP/IMMO/DTC/Start&Stop
    NO CONTACT DETAILS IN SIG NATURE
    Jul 2013
    yorkshire
    Seen this before when a ECU fitted with immo off. Didnt cause any problem or put light on. Might be can comms
    Feb 2017
    Quote Originally Posted by autoden View Post
    Thats right, there is no issue in the dashboard or in the cluster, but I would like to delete this fault. There were many things disconnected in this car... I managed to delete most of the faults
    TuningHEX
