Results 1 to 14 of 14
    audiotek's Avatar
    May 2011
    Default U3000 error in airbag modules with Infineon and Mac mcu...
    Hi friends, many times I had this error with airbag modules from Mazda and Ford:
    U3000 - INTERNAL MODULE ERROR
    Sometimes the problem was with the seatbelt pretensioners, if I put a resistor, even with the correct value (2.2 to 3.2 ohms it's ok) sometimes I retrieve this U3000 error, solution for me was the next procedure:
    1.- Disconnect the airbag module.
    2.- Remove the resistor from the seatbelt pretensioners or disconnect them if you replaced with new ones.
    3.- Reinstall the airbag module with seatbelt pretensioners disconnected.
    4.- Scan the airbag module for Dtc, now you have U3000 code and seatbelt pretensioners Dtc's
    5.- Erase Dtc's and now you can erase successfully the U3000 Dtc but seatbelts pretensioners errors remains active.
    6.- Turn off ignition switch and reconnect the seatbelt pretensioners or reinstall resistors.
    7.- Turn ignition switch on and scan and erase Dtc.
    In modules with Infineon mcu sometimes the problem is with pin 61 (P0.3), if this pin goes to ground you will retrieve dtc U3000.
    To successfully read this mcu need to lift pins 60 (P10.1) and 62 (P10.2) and connect it together to the programmer (B6 pin in xprog as example), need to lift those pins because they are originally grounded and here comes the problem: sometimes when we lift these pins accidentally short the pin 61 to ground and the module retrieves the DTC U3000 , need to lift these pins, check if the pin 61 is not shorted to ground and clean carefully any trace of solder paste.
    Unfortunatelly sometimes the problem is the ic driver that controls the deployment of the airbags and pretensioners, in this case the better solution is the replacement of the airbag module. I never tried to repair because is very risky, we can deploy an airbag by accident if the ic driver is not good or if we make any error with soldering.
    If we clear the crash data and retrieves dtc U3000 maybe we cleared most than needed but is easy to check this: rollback the original saved file and if the dtc U3000 is not present then we have a bad clearing.
    I share this as my OWN experience with this kind of airbag modules, if someone have another solution please share with all.
    I hope this can help someone...
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
  2. The Following 21 Users Say Thank You to audiotek For This Useful Post:
    andresvargas704 (13th March, 2019), autoshop2015 (23rd May, 2018), borshch (26th October, 2017), compact (20th February, 2024), dragon100 (5th August, 2023), Ediboss (10th March, 2022), FxShaw (1st May, 2017), huzefa (19th February, 2019), janushaan (27th October, 2017), jattal786 (29th May, 2019), kachimbi (23rd January, 2024), lion0304 (19th February, 2019), milerk (6th April, 2019), mscanii (21st October, 2018), repairmymodule (1st May, 2017), slick_dick (8th February, 2018), stabiel (11th July, 2019), stas12 (24th September, 2020), Troco5773 (2nd September, 2023), wti (8th February, 2019)
  3. #2
    Aug 2016
    none
    what tools you use to reading .because i never have this problem thank you
    Canada
    i havent had this issue either,, not for Infineon and Mac
    If i helped you please press thanx
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    I have also seen u3000 with Ford modules
    audiotek's Avatar
    May 2011
    Quote Originally Posted by angel garcia View Post
    I have Xprog Box original 5.7.8, UPA usb original, Macaca programmer by Autokey. Any of them can read and write successfully Infineon and Mac.
    Dec 2016
    hi guys i have same fault after clear crash data infenion for range rover evoque
    error U3000 - INTERNAL MODULE ERROR
    any help
    Aug 2014
    Program original crash file back to module and if you have no u3000 then you clear too much
    Mar 2017
    Colombia
    if possible in new airbag.
    Last week I put another airbag dump to a different car and I throw mistake....
    or the scanner does not enter, communication error
    even if you put the same reference of the module
    example;
    renault airbag logan 285584207r to renault airbag Sandero 285584207r
    WINNER THE LOSER
  10. #9
    Jul 2016
    USA
    Does this only happens if resistance is not correct from seatbelts or seatbelts not replaced ?
    Or seatbelts and everything srs can be all good but there can be u3000 code anyways ?
  11. #10
    Aug 2014
    There is always an extended code with U3000. If your scanner supports it will show like U3000-49 or U3000-51 or U3000-xx and so on. There it will pinpoint problem. Can be hardware malfunction, but most commonly software incompatibility, like what happened to above poster...
  12. The Following User Says Thank You to repairmymodule For This Useful Post:
  13. #11
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by audiotek View Post
    Your solution work 100% with U3000 from SRS unit: EB3T-14B321-EF Ranger Wiltrack 2018
  14. #12
    huzefa's Avatar
    your R 100% many time had this error after claer i do same what you say its work good
    If I helped please press rep + thanx
  15. #13
    Nov 2016
    Enniskillen
    I have fault U3000:49 in airbag module Ford Transit 2013
    C3BT-14B321-AB
    Car never been crash. Just randomly came up fault and cant get reset.
    Is it a problem with corrupted data in XC2361 56F ? or module hardware defective?
    Does somebody has virgin file for this type of airbag module ?
  16. #14
    Jul 2014
    Hello.
    I have a similar problem.
    Ford connect
    Module: DT1T-14B321-DF
    DTC: U3000:49-80
    Tricks with pretensioners didn't work. Can someone help with this or point me in the right direction?
