Results 1 to 15 of 17
    siyadk's Avatar
    Dec 2012
    Default HOW TO GET PINCODE ON HYUNDAI SONATA 2011 IF ORIGINAL ECU IS SWAPPED
    Dear DK
    We have a Hyundai Sonata 2011 Prox model. We have learnt that this car has been in accident and totaled off and previous owner reworked the car after buying from insurance auction
    At present, the current owner lost all keys, we tried program in key and every programmer gives us same result: "Pincode incorrect" . This made us realize of the possibility of a ECU or Immo swap before hence the programmer shows invalid pin because we have been using Pincode based on VIN sticker. So if ECU+immo has been swapped from another car, the VIN would be different hence different pincode
    we dont have the VIN number of the new(current) ecu to get us pincode. How can we retrieve new VIN from ECU or the pincode. Can anyone enlighten me where the pincode is stored, ie, ECU or IMMO.
    Your help will much appreciated. Thanks in advance
    PS: we have tried one hour leave key in ignition slot and battery reset in order to get out immo lock mode
    stalonerambo
    Guest
    HI, WHAT TOOL ARE YOU USING, TO ADD PROX KEY, TO THIS MODEL:?
    stalonerambo
    Guest
    X100 PRO?
    SKP900?
    siyadk's Avatar
    Dec 2012
    i tried almost all tools including skp,x100 etc, all tools says "incorrect access code" or security code wrong" or "pincdoe error"
    Jan 2016
    What ecu is it? Should be able to read vin diagnostically from engine ecu, then convert to correct pin.
  6. The Following 2 Users Say Thank You to Cr4nky For This Useful Post:
    instakeys (8th May, 2017), phuckyall (8th May, 2017)
    Feb 2014
    The pin code is stored in the Bosch ECU in the engine bay beside the battery (diesel) .
    tango can give the pin or program in new keys
    siyadk's Avatar
    Dec 2012
    Quote Originally Posted by Cr4nky View Post
    Yes true...i thought of that but cannot connect any diagnostic device because there is no ignition on
    Sent from my SM-G935F using Tapatalk
    Jan 2016
    Bypass ignition, or connect direct to ecu
  10. The Following User Says Thank You to Cr4nky For This Useful Post:
    siyadk (6th May, 2017)
  11. #9
    siyadk's Avatar
    Dec 2012
    How would I connect to ecu directly. Can you enlighten me?
  12. #10
    siyadk's Avatar
    Dec 2012
    update :- I lost the work to another locksmith, customer was impatient
    Anyways thanks to all members input
  13. #11
    Jan 2017
    USA ����
    Yes but did the other locksmith get it done??
  14. #12
    siyadk's Avatar
    Dec 2012
    not sure...not much friendly with me
  15. #13
    Jan 2017
    You could always follow up with the customer to make sure everything worked out for them.
  16. #14
    In a van down by the river
    Quote Originally Posted by phuckyall View Post
    Can't speak for everyone but I'm hesitant to accept advice from someone named "phuckyall".
  17. #15
    siyadk's Avatar
    Dec 2012
    good one nick
  18. The Following User Says Thank You to siyadk For This Useful Post:
    indienick (5th June, 2017)
