Page 1 of 18 12345611 ... LastLast
Results 1 to 15 of 259
    Nov 2011
    Default HUSQVARNA / PIN CODE
    HUSQVARNA, AUTO MOWER 2010 , ask for a 4 DIGIT PIN code, " - - - - "
    eeprom 25LC160
  2. The Following User Says Thank You to CARPARTS For This Useful Post:
    Meat-Head (5th March, 2024)
  3. #2
    Bllinda's Avatar
    Baltic
    Enter one, two, three times the code and save three damp and ....
    today
    A topic that interests me
  4. The Following User Says Thank You to Bllinda For This Useful Post:
    rokibar (16th November, 2020)
  5. #3
    Dec 2015
    Hello, I need pin code for husqvarna automower 310. I called servise but they don`t want to unlock pin because I don`t have proof of buying automower, I am second owner!
    Can somebody help me?
  6. #4
    Bllinda's Avatar
    Baltic
    Upload damp'a here. What MCU controls eeprom?
    today
    Dec 2015
    I dont know how to do that but when i press buttom 9, i received security code KTEG TPYJ RPVO. From this code need to generate PIN code.
  8. #6
    Dec 2015
    From husqvarna manual:
    2.3 Discover the PIN code
    If you forget the PIN code for an AutomowerŪ or when
    a mower is blocked because an incorrect code has
    been stated, you can find out the right code:
    1. In input mode for the PIN code, or when the main
    menu is displayed: Hold down the 9 key for five
    seconds, a combination of letters will then be
    displayed.
    2. Contact the national service organisation and
    state the letter combination. They can then
    identify the right PIN code.
    3. Press Arrow back to exit the function.
  9. #7
    BN, Romania
    Hi where did you get that memory in autoomower 220AC? I have one to find the pin but the memory is 95160.
    WBR,
    gsm9l
  10. #8
    t77's Avatar
    Poland Lodz
    Hi from which board you read 95160? and what type is automover ,I have data from automover 310
  11. #9
    BN, Romania
    autoomower 220AC comes with that memory, unfortunately I didn't find a way to find the pin yet.
    WBR,
    gsm9l
  12. #10
    I have a aitomower 310 in same status. Have somebody found a solution?
  13. #11
    Hi, I have an automower 310 and I read three eproms memory, I figured out that the mainboard 95640 is hidden the number of attempts because of a lot of time lock.
    Don't have eprom content with a known PIN?
    I'm sorry for my bad English
  14. #12
    Hi and you have data with PIN?
    I only have data without PIN, I only know where the number of attempts is hidden. and how to reset it for time lock
  15. #13
    Europa
    Quote Originally Posted by t77 View Post
  16. #14
    Aug 2012
    Is it stored in the eeprom?
  17. #15
    Nov 2019
    Hi, HUSQVARNA, AUTO MOWER cl220 mainboard, 25cl160 eeprom,need pin code,i read dump.
    does not require a pin when turned on.
  18. The Following User Says Thank You to 0008261 For This Useful Post:
    jani10 (25th May, 2024)
