Results 1 to 5 of 5
    Jan 2016
    Default Pinout ECU Delco e83 Please! - (you will not believe it)
    Hello guys, my friend send a chevrolet onix to an garage, his assistent (big hand) he needed to get the engine..... and , he cut all inconvenience, including ecu cables
    ECU Delco E83 12654172 ABJT
    (made in USA)
    Anyone have pinouts or some info about this ?
    kind regards
    hass42's Avatar
    Aug 2012
    USA
    You need a wiring diagram?
    Hass42
    Jan 2016
    Yes yes wiring diagram, or pinouts , anything
    Jan 2016
    Okay guys i can solved this wiring trouble ....finding data i found this :
    Таблица применяемости ACDelco E83: (another vehicles with ACDelco E83)
    Chevrolet Aveo 2012 Z16XER(LDE)
    Opel Insignia A16XER(LDE)/A18XER(2H0)
    Opel Astra-J A14XER(LDD)/A16XER(LDE)/A16LET(LLU)
    Opel Corsa-D 2010 A10XEP/A12XEL/A12XER/A14XEL/A14XER(LDD)
    Opel Meriva-B A14XER(LDD)/A14NET(LUJ)
    __________________________________________________ ________________
    Pins:
    J1:14 Отключаемое напряжение (K15)
    J1:12 Неотключаемое напряжение (K30)
    J1:16 Управление Главным Реле
    J1:3 Питание после ГР (К30Р)
    J2:73 Масса
    J1:10 CAN-H
    J1:11 CAN-L
    __________________________________________________ __________--
    Using tis2000 software i found Opel Corsa D wiring diagram , the colors is not the same but pins are identicles.
    i test pin by pin .....and the ECU finally ended and working.
    I post it... maybe this help somebody.
  5. The Following 11 Users Say Thank You to chedenial For This Useful Post:
    artkiani (18th February, 2018), ascotauto (21st February, 2025), capi (2nd September, 2018), geeroam (4th May, 2019), Gintas (1st April, 2018), Hayssam1 (8th August, 2021), laurentiudania (13th July, 2024), marsete (12th March, 2018), nabilrifi (4th September, 2020), randa (9th October, 2019), wokcz (31st May, 2017)
    Apr 2014
    Romania
    I also found a helpful photo that was very useful to me, it may be useful to those who will work with this ECU.
