Results 1 to 15 of 15
    Lexas's Avatar
    Default 2012 audi A4 battery drain problem.
    Anyone had an issue with battery drain on audi a4 2012. I lock the car, but every minute i can hear clicks in different places ( parking module, amplifier, somewhere under dash, in engine compartment). modules, ecu dont go in sleep mode. Any ideas where to start, please. i get lost...
    Don't Forget Button
    Newbie QwoleQ's Avatar
    Sep 2016
    The car sleeps for a few hours.
    Check power consumption after 2 hours.
    How big a MMI update in the first place.
  3. The Following User Says Thank You to QwoleQ For This Useful Post:
    Lexas (8th June, 2017)
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by Lexas View Post
    Any faults?
    Lexas's Avatar
    Quote Originally Posted by lush29 View Post
    Any faults?
    there was a lot of faults in every module, because battery dies after every night. there is fault in rear right door module, and this door lock doesnt work. i disconnected that door at all, but battery still drains. also air conditioning sensor faulty, but i dont think it can drain batter. i tried disconnect it too. relays clicks in every module every minute.
    Don't Forget Button
    Lexas's Avatar
    Quote Originally Posted by QwoleQ View Post
    after 2 hours relays keeps clicking... What you mean about MMI update, i dont understand?
    Don't Forget Button
    lush29's Avatar
    Oct 2015
    Relay clicks in every module??? What do you mean? Thats your problem then... car is looking for something....door lock, can you check drainage?
    Aug 2016
    when you start the car you chould have 14v in the batterie voltage. that mean the batterie is in charging. unlesse 14v you have to change the alternator
    it's my pleasure to help you
  9. The Following User Says Thank You to hk06 For This Useful Post:
    Lexas (9th June, 2017)
  10. #8
    Lexas's Avatar
    battery is new, charging ok. I understand that something doesnt lets modules to sleep. but why every module, at least most of them, get some signal every minute, that makes relays click. battery drainage is terrible. after i lock car with remote it stays at 3.30 amps and at the moment of relays click jumps up to 5...
    Don't Forget Button
  11. #9
    lush29's Avatar
    Oct 2015
    And if you don't lock car is still the same?
  12. #10
    Lexas's Avatar
    yes. any idea where can gateway module located on this model?
    Don't Forget Button
  13. #11
    Aug 2011
    Spalding
    Has this car got Bluetooth?
  14. The Following User Says Thank You to MJRVR For This Useful Post:
  15. #12
    Lexas's Avatar
    Quote Originally Posted by MJRVR View Post
    i dont know if car equiped with bluetooth. if so, bluetooth can make this?
    Don't Forget Button
  16. #13
    Lexas's Avatar
    Guys, check video, to see exactly whats going on.
    https://youtu.be/1yXe7dRz3dY
    https://youtu.be/dg6IT-6UJb8
    Sent from my SM-G928F using Tapatalk
  17. #14
    lush29's Avatar
    Oct 2015
    Pull fuse by fuse and see if drainage stops. When drainage stops go and look on diagram what fuse is that for.
  18. The Following User Says Thank You to lush29 For This Useful Post:
    Lexas (10th June, 2017)
  19. #15
    Lexas's Avatar
    Sorted... problem was, led bulbs in car interior lighting, that customer installed himself 😂 After remove led bulbs, relays stops clicking and battery drain drops to 0.01
    Don't Forget Button
