Results 1 to 15 of 22
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Default Golf 7 cluster pinout
    Does anyone have + and - pinout for Golf 7 cluster?
    It should show mileage with trip button pressed?
    Regards,
    Sima
    1 = 12v
    10= GND
    17 = can Low
    18 = can High
    8+9 = Coil
  3. The Following 16 Users Say Thank You to gijsvm For This Useful Post:
    aeadiag (10th January, 2018), Fallen (17th March, 2023), H2Deetoo (16th June, 2017), habbyb (24th April, 2024), jacostanzo (29th January, 2018), kaToo (28th January, 2022), m_yura (16th June, 2017), Nicolas9 (10th July, 2019), Pali33 (11th October, 2018), sagie1zn (16th June, 2017), salkapone (15th June, 2017), sanchos (29th October, 2024), simaservis1108 (15th June, 2017), stefyhgs (24th October, 2017), titodash (19th April, 2021), zahir09 (12th May, 2023)
    Nov 2015
    I can't communicate with cluster using this pinout, the cluster iluminates and shows all the info on the display, but I have no communication with no diagnostic tool, what am I missing?
    Maartinj's Avatar
    Nov 2010
    to see distance need power only and press button
    What device you use to communicate ?
    VCDS always need GW , VVDi can connect directly
  6. The Following User Says Thank You to Maartinj For This Useful Post:
    Faraday (3rd March, 2018)
    Feb 2016
    I want to do the ignition on the golf 7 table.
    What do I need?
    I have dash, key and coil
  8. #6
    Aug 2015
    For ignition need canbus emulator
  9. #7
    Feb 2016
    Do you know what emulator?
  10. #8
    Feb 2016
    can not connect dash with gateway?
  11. #9
    Aug 2015
    I connected bcm dash gw kessy but cluster is dark
  12. #10
    Jan 2016
    There is no WakeUp cable from BCM so it should communicate on table with tool like VVDI2... ??
  13. The Following 2 Users Say Thank You to amigokola For This Useful Post:
    Carsoft2003 (2nd October, 2022), lurossi (24th November, 2024)
  14. #11
    Feb 2016
    yes, but how to make the ignition
  15. #12
    May 2016
    Kaunas
    Quote Originally Posted by wojtass View Post
    Try to ask these people
    EMULATOR
  16. #13
    Jul 2016
    Just send anything on can. i have done it several times. Or use broadcast id 0x700 and whatever in data. Dash wakes up for about 10-20 secs and goes to sleep again.
    Baudrate 500k. After wakeup you can send even commands to it no problem.
  17. The Following User Says Thank You to steveleo For This Useful Post:
    amigokola (10th February, 2018)
  18. #14
    May 2016
    Ukraine
    Quote Originally Posted by gijsvm View Post
    1 = 12v
    10= GND
    17 = can Hi
    18 = can low
    8+9 = Coil
    On dash 5G1920741 i have
    1 = 12v
    10= GND
    17 = can LOW
    18 = can HI
    8+9 = Coil
  19. The Following 2 Users Say Thank You to babitur For This Useful Post:
    branci2008 (1st May, 2020), filiprow (17th May, 2023)
  20. #15
    Maartinj's Avatar
    Nov 2010
    MM-007 can simulate
