Results 1 to 2 of 2
    audiotek's Avatar
    May 2011
    Default 2007 Mazda CX-7 PCM replacement
    Hi, I need your help with this car:
    2007 Mazda CX-7 2.3L Turbo
    I replaced the PCM with a used unit from ebay. I used Mazda IDS v105.06.
    I follow this steps:
    - Go to Module reprogramming > Programmable Module Installation, the program ask if VIN number is correct, I choose "No" then I write the original VIN of car, programming finished without any issues.
    -Go to BODY > Pats Functions, then the program give me two Outcodes: HEC and PCM, I get the incodes and the program accept the incodes : "Security Access Granted", then choose "Parameter Reset" program responds : "Operation Successfull".
    -Go to "Erase and reprogram keys" , program ask what module was replaced, I choose "PCM", program ask for two keys, I follow the steps and program the two keys, the car starts perfect, no DTCs present.
    The problem: I can't change the VIN number.
    Xprog Box Original, UPA Original, GromCalcTool,TL866A, Carprog, Renesas H8SX,Obdstar X300DP, EZ500, CHIPSOFT MID, Vagcom Original, Witech OEM, Ford VCM II OEM, Mazda VCM II, Volvo Vida-Dice, Hyundai & Kia GDS, MUT III, Ford & Mazda VCX, TS401, Cardaq-m, VAS5054 Plus, JLR , Cardaq 3 Plus, Launch x431 Pro3, Renault Can Clip, VVDI prog, Autel iM608, GM DPS, CDA6, Nissan Ners, Consult III Plus, Techstream, Honda HDS and iHDS, MMC flasher, Mazda MDS, Forscan, HP Tuner, Miniprog.....
    audiotek's Avatar
    May 2011
    I already replaced many PCM in Mazda cars, Mazda 3, Mazda 5, Mazda 6, Mazda Tribute... , and I can change the VIN number too, but in this car I can't change the VIN number. I also tried with Ecu reprogramming but the software in PCM is the last one, there is not any update available...
    Also I readed the PCM with KESS v2 by OBD, edited the VIN in readed file but I can't change the VIN, even if I use writing or Recovery mode in KESS v2 software.
