Hello folks
I have a BMW X3 E83 3,0L 2004 with a DME MS45.0 WK93016 Index 02 that causes the car to shut down on idle after about 5-10 minutes.
Turn the key off/on and the car starts right upp again and runs for a couple of minutes then the same thing. Driving at the interstate gives the same symptoms as a faulty camshaft possitionsensor. I have all the "classic" error codes pointing at a broken DME and nothing on a faulty sensor. I think it's the correct assumption and that it after some minutes after the heat is build up in the circuits and the box it gets a read/write error causing the checksum to be wrong causing the DME to shut down. I have a feeling that it occurse more frequent with raising temp but can't provoke it to shut down believing that I can fix a donor and get the right read out from my original DME.
Anyhow - that was not my concern really, It's this:
MS45.0 WK93016 Index02 was placed in several 5 series E60 cars 2,0 L to 3,0L from 2003-2004 so I would get the hold of one pretty easy and my thought is that it's just a computer with some transistors for the injectors and so on so it doesn't matter what kind of car it comes from 520,525,530 or a X3 gasoline as long as it is WK93016 Index02 and as long as I don't plan to use both the EWS and the DME from the donor car not programming the DME because then I understand that it has to be exacly the right DME?
I plan to clone my faulty one to a better used one so all the code will be exchanged in the donor with my original code.
